Is there any way to do a Crop operation in a drawing view using iventor API?
thanks In advance.
Mario.
thanks In advance.
Mario.
No official API exposed for the crop operation yet.
But you can try below workaround:
Sub CreateCropView()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.Sheets(1)
Dim oDrawingView As DrawingView
Set oDrawingView = oSheet.DrawingViews(1)
Dim oSk As DrawingSketch
Set oSk = oDrawingView.Sketches.Add
oSk.Edit
oSk.SketchCircles.AddByCenterRadius ThisApplication.TransientGeometry.CreatePoint2d(0, 0), 2
oSk.ExitEdit
Me.SelectSet.Select oSk
Dim oDef As ControlDefinition
Set oDef = ThisApplication.CommandManager.ControlDefinitions("DrawingCropViewCmd")
oDef.Execute
End Sub
Hope this helps.
Fantastic!, That is what I needed.
Thank you very much.
Mario.
