Move Ordinate Dimension text
Mario-Villada
Mario-Villada
Hello everyone,
after placing ordinate dimensions  I would like to move the dimension text a bit upwards, I tried by specifying new coordinates of their jogpoints, and the text origin but it does not do anything,
This is what I have:
For i:= 1 to sktch.SketchLines.Count do
Begin
  sktL1:= sktch.SketchLines.Item[i];
  oGIntent := oSheet.CreateGeometryIntent( sktL1,kStartPointIntent);
  oPt:= sktL1.Geometry.StartPoint;
  oPt := oDV.DrawingViewToSheetSpace(oPt);
  oPt.X := oPt.X+0.5;
  oPt.Y := oPt.Y+1;
  OrdDim := oSheet.DrawingDimensions.OrdinateDimensions.Add(oGIntent,oPt,kHorizontalDimensionType,emptyparam,emptyparam);
  OrdDim.JogPointOne.X := oPt.X+0.5;
  OrdDim.JogPointOne.Y := oPt.Y+0.5;
  OrdDim.JogPointTwo.X := oPt.X+1;
  OrdDim.JogPointTwo.Y := oPt.Y+0.5;
  dimStr := OrdDim.Text.FormattedText;
  OrdDim.Text.FormattedText := 'RL ' +DimStr ;
End;
there is no error message, and the code finishes successfully, but the dimension texts remain in the same place.
any Ideas why?
I read back the coordinates of the jogpoints before and after changing their coordinates and they do not change, as if they were read only. any suggestion?
Mario.
YuhanZhang
Hi Mario,
You could try below sample code to move ordinate dimension text position:
Sub MoveOrdinateDimTextPosition()
    Dim oSheet As Sheet
    Set oSheet = Me.Sheets(1)
    Dim oDim As OrdinateDimension
    For Each oDim In oSheet.DrawingDimensions.OrdinateDimensions
        Dim oPos As Point2d
        Set oPos = oDim.Text.Origin
        oPos.Y = oPos.Y + 0.2
        oDim.Text.Origin = oPos
    Next
End Sub
 Note that the JogPointOne is a Point2d object(transient geometry), and when you want to set it you should do it like:
Set oPt = OrdDim.JogPointOne
oPt.Y = oPt.Y + 1
OrdDim.JogPointOne = oPt
 As it is transient, set value to OrdDim.JogPointOne.X does not affect the OrdDim.JogPointOne indeed.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Mario-Villada
Thanks a lot Rocky!
As usual you have been very helpful.
Mario.
Hi Rocky
i'm trying to use this code but the following message box appear
Run-time error '-2147418113 (8000ffff)
Method 'JogPointTwo' of object 'OrdinateDimension' failed
this is my code
Dim a As OrdinateDimensionSet
Set a = xsheet.DrawingDimensions.OrdinateDimensionSets.Item(1)
Set pos = a.OriginMember.JogPointTwo
pos.Y = pos.Y + 0.2
a.OriginMember.JogPointTwo = pos
where is the problem
