Crop Drawing view through API
Mario-Villada
Mario-Villada
Is there any way to do a Crop operation in a drawing view using iventor API?
thanks In advance.
Mario.
YuhanZhang
No official API exposed for the crop operation yet.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
YuhanZhang
But you can try below workaround:
Sub CreateCropView()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.Sheets(1)
    Dim oDrawingView As DrawingView
    Set oDrawingView = oSheet.DrawingViews(1)
    Dim oSk As DrawingSketch
    Set oSk = oDrawingView.Sketches.Add
    oSk.Edit
    oSk.SketchCircles.AddByCenterRadius ThisApplication.TransientGeometry.CreatePoint2d(0, 0), 2
    oSk.ExitEdit
    Me.SelectSet.Select oSk
    Dim oDef As ControlDefinition
    Set oDef = ThisApplication.CommandManager.ControlDefinitions("DrawingCropViewCmd")
    oDef.Execute
End Sub
 Hope this helps.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Mario-Villada
Fantastic!, That is what  I needed.
Thank you very much.
Mario.
