Creating Drawings automatic
I have created an I-factory of Parts and I have a master drawing ready. I am trying find something that will create drawings for every member of the I-factory.
Vladimir.Ananyev
If you put the first iPart member to the 1st drawing sheet,
then the following VBA macro could create sheets for all other members
using method shown in this video
 http://www.youtube.com/watch?v=7Y2lgdPf7dM
Sub iPartMembersDrawings()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the 1st sheet - master
    Dim oMasterSheet As Sheet
    Set oMasterSheet = oDrawDoc.Sheets.Item(1)
    'reference to the base view (assume it is the 1st view)
    Dim oMasterView As DrawingView
    Set oMasterView = oMasterSheet.DrawingViews.Item(1)
    'reference to the referenced part
    Dim oDoc As Inventor.PartDocument
    Set oDoc = oMasterView.ReferencedDocumentDescriptor.ReferencedDocument
    Call oDoc.Update
        Dim oFactory As iPartFactory
        Dim oMember As iPartMember
        Dim MemberName As String
        Dim oTargetSheet As Sheet
        Dim oTargetView As DrawingView
        Dim i As Integer
    'part definition
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    If oCompDef.IsiPartMember Then
        'this is iPart member
        Set oMember = oCompDef.iPartMember
        MemberName = oMember.Row.MemberName
        'reference to the factory object
        Set oFactory = oMember.ParentFactory
        'loop through the factory table rows 2..Count
        For i = 2 To oFactory.TableRows.Count
            'create new sheet
            Set oTargetSheet = AddNewSheet_Using_Command(oMasterSheet)
            ' copy all views from Master sheet to the new sheet
            Call CopyAllDrawingViews(oMasterSheet, oTargetSheet)
            ' base view on the target sheet
            Set oTargetView = oTargetSheet.DrawingViews.Item(1)
            MemberName = oFactory.TableRows.Item(i).MemberName
            oTargetView.ActiveMemberName = MemberName
            'show member name in the view's label
            'for debugging purposes only
            oTargetView.Label.FormattedText = MemberName
            oTargetView.ShowLabel = True
            oTargetSheet.Update
        Next i
    Else
        MsgBox "Put the 1st member to the 1st sheet"
    End If
    Beep
End Sub
Function AddNewSheet_Using_Command(ByRef oSourceSheet As Sheet) As Sheet
    Dim oDoc As DrawingDocument
    Set oDoc = oSourceSheet.Parent
    Dim oCopyCmd As ControlDefinition
    Set oCopyCmd = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingNewSheetCtxCmd")
    oCopyCmd.Execute
    Set AddNewSheet_Using_Command = oDoc.Sheets.Item(oDoc.Sheets.Count)
End Function
Sub CopyAllDrawingViews(ByRef oSourceSheet As Sheet, _
                        ByRef oTargetSheet As Sheet)
    oSourceSheet.Activate
    ' Select all the views to copy
    oDoc.SelectSet.Clear
    Dim oView As DrawingView
    For Each oView In oSourceSheet.DrawingViews
        Call oDoc.SelectSet.Select(oView)
    Next
    ' Execute the copy command
    Set oCopyCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd")
    Call oCopyCmd.Execute
    ' Activate and select the destination sheet
    oTargetSheet.Activate
    oDoc.SelectSet.Select oDoc.ActiveSheet
    ' Execute the paste command
    Dim oPasteCmd As ControlDefinition
    Set oPasteCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd")
    Call oPasteCmd.Execute
End Sub
Hope this helps.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
