Iemitating Extrusion Feature
NemKumar
NemKumar
I have 3D input device, which can be used as alernative to mouse. With this device I can get X,Y,Z co-ordinate in space.
I want to simulate the Extrusion feature on model. For this I am using Definition.SetDistanceExten() API . But it is way too slow. Is there any alternative API by which I can Simulate Extrusion, where the response is better ?
Any Idea about how can I invoke Extrusion API from CommandManagaer ?
wayne.brill
Have you considered using ClientGraphics for this? You can use client graphics to give the user a preview and then create or modify the feature when the user is ok with it.  There is a lot of discussion and samples in the API help file. (This one for example - ClientGraphics3DPrimitives)
These Blog posts could be of interest. (There are others as well - search clentGraphics)
http://modthemachine.typepad.com/my_weblog/2012/08/discussion-on-client-graphics.html
http://modthemachine.typepad.com/my_weblog/2012/08/discussion-on-client-graphics-segment-2.html
http://modthemachine.typepad.com/my_weblog/2012/08/discussion-on-client-graphics-segment-3.html
http://modthemachine.typepad.com/my_weblog/2012/08/discussion-on-client-graphics-segment-4.html
You can run Inventor commands from the API. See this DevBlog post:
http://adndevblog.typepad.com/manufacturing/2012/05/how-to-find-internal-command-names.html
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
