Creating automatic note number
86171VLTWG_2014_0F
Observer Observer
86171VLTWG_2014_0F
Observer
Observer
I want an iLogic rule that creates an increasing text number string each time I insert a note into an Inventor drawing of type: "W001", W002" etc.  Any help is greatly appreciated!
bradeneuropeArthur
I could create you an add-in for that!
Is that also ok?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
86171VLTWG_2014_0F
Observer
Observer
Thanks, that would be great!!
C_Haines_ENG
I know @bradeneuropeArthur is making an Add-In but I thought I'd have a crack at it. With this code you can place multiple note leaders and it will name them all correctly! Just place the note leader how you normally would but don't enter any text! When you hit escape to back out of the tool it will update the names. Enjoy!
Sub Main
	Dim oDoc As DrawingDocument = ThisDoc.Document
	Dim oLeaderNotes As LeaderNotes = oDoc.ActiveSheet.DrawingNotes.LeaderNotes
	Dim oCount As Integer = oLeaderNotes.Count
	Dim oHighestNumber As New List(Of Integer)
	For Each oLeader As LeaderNote In oLeaderNotes
		If oLeader.Text.StartsWith("W")
			oHighestNumber.Add(Right(oLeader.Text, 2))
	Next
	ThisApplication.CommandManager.ControlDefinitions("DrawingLeaderTextCmd").Execute2(True)
	Dim oNoteNum As Integer = 1
	If oHighestNumber.Count <> 0 Then oNoteNum = oHighestNumber.Max + 1
	If oLeaderNotes.Count - oCount >= 1
		For i = oLeaderNotes.Count - (oLeaderNotes.Count - oCount) + 1 To oLeaderNotes.Count
			Select Case oNoteNum
				Case < 10
					oLeaderNotes(i).Text = "W00" & oNoteNum
				Case < 100
					oLeaderNotes(i).Text = "W0" & oNoteNum
				Case >= 100
					oLeaderNotes(i).Text = "W" & oNoteNum
			End Select
			oNoteNum += 1
		Next
	Else
		Exit Sub
End Sub
