Creating asymmetric revolve feature.
Jef_E
Jef_E
Hello there,
I am having difficulties creating a revolve feature in TWO directions based on angle value.
I think this is the required method, but it does not allow me to set asymmetric extent direction. Please help 😄
RevolveFeatures.AddByAngle Method
Description
Method that creates a new RevolveFeature that sweeps a specified angle. The new RevolveFeature is returned.
Syntax
RevolveFeatures.AddByAngle( Profile As Profile, AxisEntity As Object, Angle As Variant, ExtentDirection As PartFeatureExtentDirectionEnum, Operation As PartFeatureOperationEnum ) As RevolveFeature
PartFeatureExtentDirectionEnum Enumerator
Description
Constants identifying the direction in which a feature extension needs to take place.
Methods
Name Value Description
kNegativeExtentDirection 20994 Extension in the negative direction.
kPositiveExtentDirection 20993 Extension in the positive direction.
kSymmetricExtentDirection 20995 Extension in positive AND negative direction.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
llorden4
Anybody? I need to figure this out as well.
I am finding documentation on the "ExtentTwo" option but everything is read only, so not sure how I'm supposed to define those values if they're read only.
Autodesk Inventor Certified Professional
