Creating a sketch and Converting Parameters using iLogic
Hi all,
I'm having trouble creating and converting parameters and would love some help, of course, I'm new to iLogic and I'm sure what I'd like to do is simple for most.
What we currently do:
I create two sketches in a finished assembly and then use those Parameters as LENGTH, WIDTH, THICK all in mm then I Create user parameters manually as ELENGTH, EWIDTH, ETHICK and use the LENGTH, WIDTH, THICK Parameters and set the units to in, Fractional, 1/16 precision.
Priority/Question 1:
I'd like to automate this with iLogic and have the rule either create the sketch and all the parameters for me including setting the "Custom Property Format" or skip the sketch but still grab the required dims to create the parameters needed, this would help so much to speed up the process for everyone in my dept.
"else if" Priority/Question 2:
If creating the sketch or grabbing the dims is to complicated I would atleast like to know how to convert the LENGTH, WIDTH, THICK Parameters to ELENGTH, EWIDTH, ETHICK and set the "Custom Property Formats" for both mm and inches.
See the attached image if it helps.
Thank you! Any help with this would be greatly appreciated.
