Create workpoint on assembly geometry
David-Truyens
Message 1 of 10
David-Truyens
I would like to create a workpoint on a geometry at the assembly level. So not a fixed, but with a constraint to that selected point. Any idea? If I use the Pick with a point filter I just get the coordinates, but not the id of the point itself.
David
Replies (9)
Message 2 of 10
bradeneuropeArthur
Hoi David,
So you need to create a point without directly attached to the geometry, but with constaints to the geometry?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
David-Truyens
Hi Brad,
What do you mean with "without directly attached"? If you create a workpoint on assembly level and would like it to move with the component it needs a constraint between the workpoint and the geometry as far as I know. If you know another way I'll be glad to learn it!
David
Message 4 of 10
bradeneuropeArthur
Hoi David,
Maybe I don't understand, but the workpoints are per default constraint as seen bellow:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
David-Truyens
Hi Brad,
I'm sorry, I should mention that I would like to do this via the API. So you have a "pick" function where you can select a point and then it should create a workpoint on that selected point with a constraint.
Message 6 of 10
bradeneuropeArthur
Hallo David,
I will take a look at this.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
bradeneuropeArthur
This is how:
Public Sub MatePointConstraint()
    ' Set a reference to the assembly component definintion.
    Dim a As Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
Dim c As AssemblyComponentDefinition
Set c = b.ComponentDefinition
Dim p As Point
Dim w As WorkPoint
Set p = ThisApplication.TransientGeometry.CreatePoint(0, 0, 0)
Set w = b.ComponentDefinition.WorkPoints.AddFixed(p, False)
Dim oObject As Object
Dim cmd As CommandManager
Set cmd = ThisApplication.CommandManager
Set oObject = cmd.Pick(kAllPointEntities, "Pick a feature")
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    ' Set a reference to the select set.
    Dim oSelectSet As SelectSet
    Set oSelectSet = ThisApplication.ActiveDocument.SelectSet
    ' Get the two entities from the select set.
    Dim oBrepEnt1 As WorkPoint
    Dim oBrepEnt2 As Object
    Set oBrepEnt1 = w
    Set oBrepEnt2 = oObject
    ' Create the insert constraint between the parts.
    Dim oMate As MateConstraint
    Set oMate = oAsmCompDef.Constraints.AddMateConstraint(oBrepEnt1, oBrepEnt2, 0)
End Sub
Groetjes,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
David-Truyens
Looks good! Didn't have time to test it yet.. I'll make sure I'll do that this week.
David
ps: kennen wij elkaar? 🙂
Message 9 of 10
bradeneuropeArthur
Hoi David,
Sure it works, I have tested in inventor 2018.
You will see.
De Groeten,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
bradeneuropeArthur
I have send you a short private message.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
