Create work point from axis and plane
hieut1392
605 Visites
5 Réponses
Message 1 sur 6
hieut1392
I want to create work point from intersection of axis and plane. Can you give me some hint?
Sub CreateWorkPoint()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
Dim face As Object
Set face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Face")
Dim axis As Object
Set axis = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Axis")
Call oCompDef.WorkPoints.Addby <---- I'm stuck here
End Sub
0 J'aime
Solutions acceptées (1)
606 Visites
5 Réponses
Message 2 sur 6
WCrihfield
Hi @hieut1392.  Here is something you can try out.  I just wrote this as a general iLogic rule, so I'm just using Sub Main, but you can change that if you need to.
Sub Main
	'pick face
	oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Pick Flat Face.")
	If oObj Is Nothing OrElse (TypeOf oObj Is Face = False) Then Return
	Dim oFace As Face = oObj
	Dim oPlane As Plane = oFace.Geometry
	'pick work axis
	oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkAxisFilter, "Pick Work Axis.")
	If oObj Is Nothing OrElse (TypeOf oObj Is WorkAxis = False) Then Return
	Dim oAxis As WorkAxis = oObj
	Dim oPoint As Point = oPlane.IntersectWithLine(oAxis.Line)
	Dim oPDef As PartComponentDefinition = oFace.Parent.ComponentDefinition
	oPDef.WorkPoints.AddByPoint(oPoint)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
0 J'aime
Message 3 sur 6
Michael.Navara
Solution acceptée
The code mentioned by @WCrihfield doesn't work for me. Argument for method AddByPoint must be SketchPoint or Vertex.
Modified code below creates two types of WorkPoints. Fixed and constrained. See the comments.
Sub Main
	'pick face
	'pick work axis
	oPDef.WorkPoints.AddFixed(oPoint) 'Creates fixed workpoint
	oPDef.WorkPoints.AddByCurveAndEntity(oAxis, oFace) 'Creates WorkPoint constrained to workAxis and Face
End Sub
Message 4 sur 6
WCrihfield
Good catch @Michael.Navara.  I must not have been paying close enough attention at the time.  It happens when thinking about too many things at the same time. 🤔😉
Edit:  I guess they need to update their documentation for the AddByCurveAndEntity method, to state that you can alse use a WorkAxis as input for the 'Curve' variable.  Documentation currently just says that it must be an Edge, or 2D sketch entity, or 3D sketch entity.  I did not think that a WorkAxis qualified as any of those.
Wesley Crihfield
0 J'aime
Message 5 sur 6
hieut1392
this code doesn't work for me too, but thank you any way.
0 J'aime
Message 6 sur 6
hieut1392
thank you.
0 J'aime
