Create sheetmetal face with multiple flanges
Cadkunde.nl
Cadkunde.nl
Attached I got a part (inventor 2020) with an ilogic rule.
The part is like a skeleton model, and the script creates a new part with the skeleton derived in.
The user gets a prompt to select a face.
The script then has to make a sheetmetal face and flanges on the edges.
The script crashes when trying to make the second flange.
It works when i select all edges and then make 1 flange.
But I want to make 1 flange per edge, so that I can later add an angle to each.
I am clueless why the script crashes on making the 2nd flange.
Any help is greatly appreciated.
JelteDeJong
The problem here is that you want to use the topFace multiple times. After the first time you add a flange, the face (and edges) stop existing. It will be transformed into a new face. (at best it will look like the old face but smaller because of the radius of the flange.) Therefore you can't use that face any more. you need to select the new face or one of the new edges.
in the example below you can select the edges manually so you can see it can work.
Dim oApp As Inventor.Application = ThisApplication
Dim oDoc As PartDocument = ThisDoc.Document
Dim templateFilePath = "C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates\en-US\Sheet Metal.ipt" ' ThisApplication.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject)
Dim template As PartDocument = oApp.Documents.Add(DocumentTypeEnum.kPartDocumentObject, templateFilePath, True)
Dim oDerivedPartDef As DerivedPartUniformScaleDef = template.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oDoc.FullFileName)
template.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
oApp.CommandManager.ControlDefinitions.Item("AppViewCubeHomeCmd").Execute()
oApp.ActiveView.Fit()
Dim oFace As Face = oApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select face")
If (oFace.SurfaceType <> SurfaceTypeEnum.kPlaneSurface) Then Exit Sub
Dim oSketch As Inventor.PlanarSketch = template.ComponentDefinition.Sketches.Add(oFace)
oSketch.Edit()
Dim oEdgeLoop As Inventor.EdgeLoop = oFace.EdgeLoops(1)
For Each oEdge As Inventor.Edge In oEdgeLoop.Edges
	oSketch.AddByProjectingEntity(oEdge)
Next
oSketch.ExitEdit()
Dim oProfile As Profile = oSketch.Profiles.AddForSolid() ', Profile
Dim cd As SheetMetalComponentDefinition = template.ComponentDefinition
Dim oSMF As SheetMetalFeatures = cd.Features
Dim oFFD As FaceFeatureDefinition = oSMF.FaceFeatures.CreateFaceFeatureDefinition(oProfile)
Dim oFF As FaceFeature = oSMF.FaceFeatures.Add(oFFD)
Do
	Dim edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeLinearFilter, "Select edge")
	If (edge Is Nothing) Then Exit Do
	Dim edgeSet As EdgeCollection = ThisApplication.TransientObjects.CreateEdgeCollection
	edgeSet.Add(edge)
	Dim flangeDef As FlangeDefinition = oSMF.FlangeFeatures.CreateFlangeDefinition(edgeSet, "90", 5)
	oSMF.FlangeFeatures.Add(flangeDef)
Loop
Jelte de Jong
Blog: hjalte.nl - github.com
A.Acheson
Just once change needed. It seems that the edges selected from the solid body will be modified by the added flange and therefore won't existing to add to the edgeset. If you take the edge collection directly from the face selected this will be solved.
Dim topFace As Face = oFF.Faces.Item(6)
Update Rule:
Dim oPartDoc As PartDocument
oPartDoc = oApp.Documents.Add(DocumentTypeEnum.kPartDocumentObject, "C:\Templates\Sheet Metal.ipt", True) 'ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject)
Dim oDerivedPartDef As DerivedPartUniformScaleDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oDoc.FullFileName)
oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
If Not oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then Exit Sub
oPlanarSurface = oFace.Geometry
Dim oSketch As Inventor.PlanarSketch = oPartDoc.ComponentDefinition.Sketches.Add(oFace)
oSketch.Edit
Next
oSketch.ExitEdit
Dim oProfile As Profile = oSketch.Profiles.AddForSolid(), Profile
Dim cd As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
Dim tg As TransientGeometry = ThisApplication.TransientGeometry
Dim topFace As Face = oFF.Faces.Item(6)'cd.SurfaceBodies.Item(1).Faces.Item(6)
Dim i As Integer
For Each oEdge In topFace.Edges
	edgeSet.Clear
	flangeDef = oSMF.FlangeFeatures.CreateFlangeDefinition(edgeSet, "90", 5)
	edgeSet.Add(oEdge)
Next
Regards
Alan
Cadkunde.nl
thanks guys, much appreciated.
This did the trick:
But I'll add both as solution. The explanation is clear.
