Creating X amount of rows in a custom form in a drawing
alex.papuga
alex.papuga
Hi All,
I have a function that creates a custom form in a drawing which is working almost as I need. I pass the function a part number and it populates the columns based on that. This works fine (code included below), however what I want to be able to do is pass X amount of part numbers to the function, then a new row created for each part number.
How would I go about doing this?
Thanks in advance.
Function funcCustomTable(strPartNo As String)
Logger.Debug("funcCustomTable run with strPartNo: " + strPartNo)
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
Dim oCols As Integer = 4
Dim oRows As Integer = 1
Select Case strPartNo
Case "1234567"
	strDesc = "description of part"
End Select
' Set the column titles
Dim oTitles(3) As String
oTitles(0) = "ITEM"
oTitles(1) = "PART NO"
oTitles(2) = "QTY"
oTitles(3) = "DESCRIPTION"
Logger.Debug("Titles Created")
' Set the contents of the custom table (contents are set row-wise)
Dim oContents(3) As String
oContents(0) = "1"
oContents(1) = strPartNo
oContents(2) = 1
oContents(3) = strDesc
Logger.Debug("Contents Created")
' Set the column widths (defaults to the column title width if not specified)
Dim oColumnWidths(3) As Double
oColumnWidths(0) = 1
oColumnWidths(1) = 2.9
oColumnWidths(2) = 1
oColumnWidths(3) = 9.7
Logger.Debug("Widths Adjusted")
oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(15, 15)
Logger.Debug("Placement Point Added")
' Create the custom table
Dim oCustomTable As CustomTable
Try
	oCustomTable = oSheet.CustomTables.Add("SUBSTITUTE MATERIAL", oPlacementPoint, oCols, oRows, oTitles, oContents, oColumnWidths)
Catch ex As Exception
Logger.Debug(ex.ToString)
End Try
JelteDeJong
try something like this:
Sub Main()
	Dim partNumbers As New List(Of String)
	partNumbers.Add("1234567")
	partNumbers.Add("8901234")
	funcCustomTable(partNumbers)
End Sub
Public Function funcCustomTable(partNumbers As List(Of String))
	Dim strDesc = String.Empty
	logger.Debug("Contents Created")
	oTitles(0) = "ITEM"
	oTitles(2) = "QTY"
	logger.Debug("Titles Created")
	logger.Debug("Widths Adjusted")
	Dim oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(15, 15)
	logger.Debug("Placement Point Added")
	Try
		Dim firstPartNumber = partNumbers.First()
		partNumbers.Remove(firstPartNumber)
		Dim content = createRowContent(firstPartNumber)
		oCustomTable = oSheet.CustomTables.Add("SUBSTITUTE MATERIAL", oPlacementPoint, oCols, oRows, oTitles, content, oColumnWidths)
		For Each partNumber As String In partNumbers
			content = createRowContent(partNumber)
			oCustomTable.Rows.Add(,, content)
		Next
		logger.Debug(ex.ToString)
	End Try
End Function
Public Function createRowContent(partNumber)
	Dim description = "Unknown"
	Select Case partNumber
		Case "1234567"
			description = "description of part"
		Case "8901234"
			description = "description of part 2"
	End Select
	Dim content(3) As String
	content(0) = "1"
	content(1) = partNumber
	content(2) = 1
	content(3) = description
	Return content
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
A.Acheson
Here is one approach. Create an empty table then add a row and populate then move to the next.
Sub Main
	Dim strPartNoList As New List(Of String)
	strPartNoList.Add("1234567")
	strPartNoList.Add("123")
	strPartNoList.Add("12345")
	For Each strPartNo In strPartNoList
		funcCustomTable(strPartNo)
	Next
End Sub
	If oSheet.CustomTables.Count = 0 Then
		'Set the column titles.
		oTitles(0) = "ITEM"
		oTitles(2) = "QTY"
		'Set the column widths (defaults to the column title width if not specified).
		Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(15, 15)
		Try
			oCustomTable = oSheet.CustomTables.Add("SUBSTITUTE MATERIAL", oPlacementPoint, oCols, oRows, oTitles, , oColumnWidths)
		End Try
	Else
		'Get the custom table object.
		oCustomTable = oSheet.CustomTables(1)
		oCustomTable.Rows.Add()
	Dim strDesc As String
	Case "1234567"
	Case Else
		strDesc  = "N/A"
	End Select
	'Get last row number.
	Dim TableRowNo As Integer = oCustomTable.Rows.Count
	'Get row object.
	Dim TableRow As Row = oCustomTable.Rows(TableRowNo)
	'Get each cell object.
	Dim ItemCell As Cell = TableRow.Item(1)
	Dim PartCell As Cell = TableRow.Item(2)
	Dim QtyCell As Cell = TableRow.Item(3)
	Dim DescCell As Cell = TableRow.Item(4)
	'Populate the table.
	ItemCell.Value = (TableRowNo+1)-1 '-1 to Skip Header Row
	PartCell.Value = strPartNo
	QtyCell.Value = "1"
	DescCell.Value = strDesc
End  Function
Regards
Alan
alex.papuga
Thanks so much, worked as expected. Really handy to know how to pick out each cell object too.
A.Acheson
Yes this works well for quering the table after its populated. And the same approach can be used for revision table and partslist. The API help has samples for the partslist in VBA launguage.
Regards
Alan
