Get Properties of Type Class
h.schkorwaga
h.schkorwaga
Hello together,
I'm trying to get properties from an object of type DrawingView for example. (see screenshot attached)
This should be a general subroutine for all Inventor types later.
        private void CreateFinalList<T>(T obj)
            if (obj == null) return;
            List<PropertyInfo> properties = typeof(T).GetProperties().ToList();
            foreach (PropertyInfo propertyInfo in properties)
                string name = propertyInfo.Name;
Properties list keep count = 0.
What am I doing wrong?
Thank you in advance.
JelteDeJong
If I test your code it works fine. Maybe it's not your method that is not working?
Jelte de Jong
Blog: hjalte.nl - github.com
h.schkorwaga
Hello Jelte,
thank you for testing. Yes this works for a specified type (DrawingView)
The obj parameter comes from a foreach iterating through selected entities which are delivered as objects. So no special type here.
        public void OSelectEvents_OnSelect(ObjectsEnumerator JustSelectedEntities, SelectionDeviceEnum SelectionDevice, Point ModelPosition, Point2d ViewPosition, Inventor.View View)
            if (JustSelectedEntities.Count == 0) return;
            foreach (object item in JustSelectedEntities)
                CreateFinalList(item);
            StandardAddInServer.oInteractEvents.Stop();
Any ideas how this could work?
Thank you!
jjstr8
The issue is that 'item' is a System.__ComObject.  You can use Microsoft.VisualBasic.Information.TypeName(item) to get the type as a string, but you can't use Convert.ChangeType because it needs to implement IConvertible.  I'm not sure what object types are in your selection set, but you may have to have a (potentially) large if/elseif statement to cast 'item' to all types you're interested in then call CreateFinalList with a specific type.
h.schkorwaga
Yes that's the Problem, I don't want to have such large if or switch statements to handle each possible type (everything that is selectable) with casting. That's why I want to have a general working function that can handle all.
This snippet is already implemented in the OnPreselect event to check what type the preselected entity is to ensure highlighting.
        public void OSelectEvents_OnPreSelect(ref object PreSelectEntity, out bool DoHighlight, ref ObjectCollection MorePreSelectEntities, SelectionDeviceEnum SelectionDevice, Point ModelPosition, Point2d ViewPosition, Inventor.View View)
            string PreSelTypeName = Microsoft.VisualBasic.Information.TypeName(PreSelectEntity);
            List<string> typenameList = new List<string>();
            foreach (Type type in SelectionType)
                typenameList.Add(type.Name);
            if (!(typenameList.Contains(PreSelTypeName)))
                DoHighlight = false;
            else
                DrawingView drawingView = (DrawingView)PreSelectEntity;
                DoHighlight = true;
But I want to have access to the properties of the recognized type in my "CreateFinalList" function to make a cast, or maybe there is another solution(?).
jjstr8
With a little more digging, this is what I could come up with.  Note that 'InvApp' is the Inventor.Application object.  I don't know if you're just after property names, but be aware that property values that are reference types will come back as System.__ComObject.  I didn't do any additional testing to see if you can drill down further.
AppDomain appDomain = AppDomain.CurrentDomain;
Assembly[] appDomainAssemblies = appDomain.GetAssemblies();
System.Reflection.Assembly inventor = appDomainAssemblies.FirstOrDefault(a => a.FullName.StartsWith("Autodesk.Inventor.Interop"));
if (inventor != null)
    Type[] types = inventor.GetTypes();
    foreach (object item in InvApp.ActiveDocument.SelectSet)
        string typeName = Microsoft.VisualBasic.Information.TypeName(item);
        Type invType = types.FirstOrDefault(t => t.Name == typeName);
        if (invType != null)
            List<PropertyInfo> properties = invType.GetProperties().ToList();
                try
                    object propValue = propertyInfo.GetValue(item);
                catch (Exception)
                    // Do something when you can't get the value
h.schkorwaga
thank you very much - this works perfect.
Not needed atm but to drill down the mentionend generic System.__ComObject-types a recursive function could be written, I guess.
BR
