Create Outlook "Task" using ilogic
mcgyvr
Consultant Consultant
mcgyvr
Can one create an Outlook task using ilogic?
I can get an email working but not a task so far..
This seems to just create an email not a task..
oOApp = CreateObject("Outlook.Application")
oOTask = oOApp.CreateItem(olTaskItem)
oOTask.Subject = "Check Drawings"
oOTask.Display
bradeneuropeArthur
With CreateObject("Outlook.Application").CreateItem(3)
    '.Subject = UserForm1.TextBox1.Value & " " & UserForm1.ComboBox1.Value
    '.StartDate = UserForm1.MonthView1.Value
    '.DueDate = UserForm1.MonthView1.Value
    '.ReminderTime = UserForm1.MonthView1.Value - 1
    '.Body = UserForm1.TextBox1.Value & " " & UserForm1.ComboBox1.Value
    .Save
End With
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
tfrohe_LSI
I find it easiest to manually create and save a template for your tasks in Outlook. Then use the following code to create your task programmatically.
oOTask = oOApp.CreateItemFromTemplate("C:\Users\<USERNAME>\AppData\Roaming\Microsoft\Templates\My Task.oft")
oOTask.Display
This will work as expected every time.
