Create iLogic Extrusion and Drive Dimensions with Parameters
brendon.serrano
brendon.serrano
I am using Inventor 2019 4.4. I am currently making a template for standard parts. I am trying to create a button that will automatically extrude either a rectangle or a round at the origin so that the origin planes with always be at the center of the extrusion. I have been able to get the extrusion and the sketch to be created, but I run into issues when I want to edit the extrusion to be a different size. So far I have made it so that the extrusion is deleted if it already exists. I am hoping to add the functionality that the extrusion will only be edited so if there are other features on the part. they will not need to be re-made. I was hoping I could drive the extrusion with parameters, but i cannot find a way to put the parameter in as the extrude length, or drive the sketch with parameters (except for the initial creation). Below is the code I have so far. If anyone has any ideas, or any information that might help me out, please let me know. The code below is for the rectangular bar only and i have a separate code for the round, but I may want to put them both in the same function down the road.
Dim oDoc = ThisDoc.Document
If TypeOf ThisApplication.ActiveEditObject Is Sketch Then
    ' Set a reference to the active sketch.
    Dim OpenSketch As Sketch = ThisApplication.ActiveEditObject
    OpenSketch.ExitEdit
End If
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
' Get the X-Y work plane.
Dim xyPlane As WorkPlane
xyPlane = oDef.WorkPlanes.Item("XY Plane")
Try
	ExtrusionExists = ThisApplication.ActiveEditDocument.ComponentDefinition.Features("Bar Extrusion")
	ExtrusionExists.delete
	Catch
		Try
			SketchExists = ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches("Bar_Sketch")
			SketchExists.delete
			Catch
		End Try
End Try
'Try
'	ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches("Bar_Sketch").Delete
'	Catch
'End Try
' Create a new sketch.
Dim sketch As Inventor.PlanarSketch
sketch = oDef.Sketches.Add(xyPlane, True)
sketch.Name = "Bar_Sketch"
ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches("Bar_Sketch").Edit
InventorVb.DocumentUpdate()
' Check to make sure a sketch is open.
If Not TypeOf ThisApplication.ActiveEditObject Is PlanarSketch Then
MessageBox.Show("A sketch must be active.", "iLogic")
Return
End If
'set a reference to the active sketch.
Dim oSketch As PlanarSketch
oSketch = ThisApplication.ActiveEditObject
'set a reference to the transient geometry collection.
Dim oTransGeom As TransientGeometry
oTransGeom = ThisApplication.TransientGeometry
' Create a rectangle
'width = BAR_W
'height = BAR_H
'length = BAR_L
Dim oRectangleLines As SketchEntitiesEnumerator
oRectangleLines = oSketch.SketchLines.AddAsTwoPointCenteredRectangle( oTransGeom.CreatePoint2d(0, 0),oTransGeom.CreatePoint2d(BAR_W*2.54/2, BAR_H*2.54/2))
ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches("Bar_Sketch").ExitEdit
Dim extrudeProfile As Profile = sketch.Profiles.AddForSolid
Dim oExtFeature As ExtrudeFeature
oExtFeature = oDoc.ComponentDefinition.Features.ExtrudeFeatures.AddByDistanceExtent (extrudeProfile, Parameter("BAR_L")*2.54, kSymmetricExtentDirection, kJoinOperation)
oExtFeature.Name = "Bar Extrusion"
ThisApplication.ActiveView.Fit
iLogicVb.UpdateWhenDone = True
Accepted solutions (3)
Curtis_Waguespack
Hi @brendon.serrano
Here's a quick example based on what you had.
I hope this helps.
Curtis
sSketchName = "Bar_Sketch"
sExtName = "Bar Extrusion"
Dim oDoc As Document
Dim oSketch As Inventor.PlanarSketch
oW = InputBox("Enter new Width", "iLogic", BAR_H)
oL = InputBox("Enter new Length", "iLogic", BAR_L)
oH = InputBox("Enter new Height", "iLogic", BAR_H)
Try
	oExtrusion = oDef.Features(sExtName)
	GoTo _Found_Extrusion
Catch
End Try
oSketch = oDef.Sketches.Add(xyPlane, True)
oSketch.Name = sSketchName
oSketch.Edit
'' Create a rectangle
oRectangleLines = oSketch.SketchLines.AddAsTwoPointCenteredRectangle _
(oTransGeom.CreatePoint2d(0, 0), oTransGeom.CreatePoint2d(oW / 2, oL / 2))
Dim oSketchLine As Inventor.SketchLine
Dim oDim As DimensionConstraint
oSketchLine = oRectangleLines.Item(1)
oDim = oSketch.DimensionConstraints.AddTwoPointDistance _
	(oSketchLine.StartSketchPoint, oSketchLine.EndSketchPoint, _
	DimensionOrientationEnum.kHorizontalDim, _
	oTransGeom.CreatePoint2d(0, -(oW/2 )))
oDim.Parameter.Name = "BAR_L"
oSketchLine = oRectangleLines.Item(2)
	DimensionOrientationEnum.kVerticalDim, _
	oTransGeom.CreatePoint2d(oL+2, 0))
oDim.Parameter.Name = "BAR_W"
oSketch.ExitEdit
extrudeProfile = oSketch.Profiles.AddForSolid
oExtFeature = oDoc.ComponentDefinition.Features.ExtrudeFeatures.AddByDistanceExtent _
	(extrudeProfile, oH, _
oExtFeature.Parameters.Item(4).Name = "BAR_H"
_Found_Extrusion :
BAR_W = oW
BAR_L = oL
BAR_H = oH
WCrihfield
Did you know that when you place a driving dimensional constraint in a model sketch, you can specify a name for the Parameter it will be stored in.   For example you could enter "HEIGHT = 12" (without the quotes) instead of just a number, within the dimension, when placing it.  Then you can find that Parameter within the Parameters dialog box.  It will be one of the Model Parameters.
You can use the same logic within your code, to specify the name of the parameter that a feature is going to create, where specifying a dimension.  Just specify oHeight = "HEIGHT = 12" (with the quotes around the part after =  sign.
That's just for if you haven't already created UserParameters before-hand.
If you have already set-up UserParameters, you can just specify the name of the Parameter with a line like "oHeight = Parameter("HEIGHT").Value
Wesley Crihfield
(Not an Autodesk Employee)
brendon.serrano
I was able to utilized both of your suggestions for the solution. I could not just simply set the "Parameter" in when creating the sketch rectangle, but it worked well for the extrusion. I also had to change how the dimensions were named in the sketch from parameter.name to parameter.Expression. my solution can be seen below. Thank you both for your quick responses and suggestions.
    OpenSketch.ExitEdit
End If
Try
'	ExtrusionExists.delete
	width = BAR_W
	height = BAR_H
	length = BAR_L
	Catch
		Try
			SketchExists.delete
			Catch
		End Try
'End Try
'Try
'	Catch
'End Try
Return
End If
width = BAR_W
height = BAR_H
length = BAR_L
oRectangleLines = oSketch.SketchLines.AddAsTwoPointCenteredRectangle( oTransGeom.CreatePoint2d(0, 0),oTransGeom.CreatePoint2d(width*2.54/2, height*2.54/2))
	oTransGeom.CreatePoint2d(0, -(width/2 )))
'oDim.Parameter.Name = "BAR_W"
oDim.Parameter.Expression = "BAR_W"
	oTransGeom.CreatePoint2d(height+2, 0))
oDim.Parameter.Expression = "BAR_H"
oExtFeature = oDoc.ComponentDefinition.Features.ExtrudeFeatures.AddByDistanceExtent (extrudeProfile, "BAR_L", kSymmetricExtentDirection, kJoinOperation)
End Try
