ilogic together with inventor hsm/cam
hi,
I would like to know if it is posible to change cutting data of my tools when i change material in my form section of ilogic.
like change the tool feeds and speeds, ae ap and tool lenght.
i whas tinking about making multiple tool paths with difrent cutting data, but i dont know how i can link it to my material or pick the right tool paths.
do you guys know how i can do this?
mcgyvr
Only info I've found says that you can only read parameters of an operation but can't set them through the API..
hi, the problem isn't solved.
would it be posible to pick diffrent toolpaths with i logic.
like say: I got a chamber and the range goes from 30 to 150 mm deep.
               That you can pick toolpaths that got tools in them to do a range from 30 to 60 and another toolpath with                           tools from 60 to 90mm and another one from 90 to 150.
I can just change the tool propertys that way.
So i wanne know if it is posible to control hsm cam with i logic.
mcgyvr
Seems like HSM is exposed through the Inventor API...
"ilogic"... not so much..
https://forums.autodesk.com/t5/hsm-ideas/use-ilogic-for-cam-operations/idi-p/6472820
There are certainly some things you can do in regards to disabling operations,etc.....
See this video for more..
https://www.autodesk.com/autodesk-university/class/Automate-CNC-Machining-Using-Inventor-HSM-API-and-iLogic-CAM-Products-2018
