Create ILogic constraints between parts based on 3 planes chosen by the user
haphanthanhtam.work
haphanthanhtam.work
i want to create mate for 3 face of part in assembly to quickly do my work
i have below code but it is not working
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
Dim part1 As ComponentOccurrence
part1 = asmDoc.ComponentDefinition.Occurrences.Item(1)
Dim part2 As ComponentOccurrence
part2 = asmDoc.ComponentDefinition.Occurrences.Item(2)
Dim selectedPlane1 As WorkPlane
selectedPlane1 = ThisApplication.CommandManager.Pick(kWorkPlaneFilter, "Select the first plane")
Dim selectedPlane2 As WorkPlane
selectedPlane2 = ThisApplication.CommandManager.Pick(kWorkPlaneFilter, "Select the second plane")
Dim selectedPlane3 As WorkPlane
selectedPlane3 = ThisApplication.CommandManager.Pick(kWorkPlaneFilter, "Select the third plane")
Dim constraintGroup As GeometricConstraintGroup
constraintGroup = asmDoc.ComponentDefinition.Constraints.AddMateConstraint(part1, part2, kFlushMate, selectedPlane1, selectedPlane2, selectedPlane3)
Select faceSelect face
affteraffter
  • mate
A.Acheson
Hi @haphanthanhtam.work
I noticed a few mistakes you have,
  1. You were picking workplanes and not faces
  2. You were picking occurrences which is not required.
  3. GeometricConstraintGroup is not an object within the API
Here is a method that allows multiple constraints.
Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim face1 As Face
Dim face2 As Face
Dim mate1 As MateConstraint
While True
	face1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select the first face")
	' Exit loop if nothing selected
	If face1 Is Nothing Then Exit While
	face2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select the second face")
	' Create the insert constraint between the parts.
	mate1 = asmDoc.ComponentDefinition.Constraints.AddMateConstraint(face1, face2, 0)
End While
Regards
Alan
haphanthanhtam.work
Hi @A.Acheson
it's almost exact. I edited the code to suit me
Dim face1 As Face
Dim face2 As Face
	face3 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select the 3 face")
	face4 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select the 4 face")
	mate2 = asmDoc.ComponentDefinition.Constraints.AddMateConstraint(face3, face4, 0)
	face5 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select the 5 face")
	face6 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select the 6 face")
	mate3 = asmDoc.ComponentDefinition.Constraints.AddPlushConstraint(face5, face6, 0)
I need to edit this line to look like image
Can you helpe me!!
A.Acheson
You have a spelling mistake here
see API Help here
AssemblyConstraints.AddFlushConstraint( EntityOne As Object, EntityTwo As Object, Offset As Variant, [BiasPointOne] As Variant, [BiasPointTwo] As Variant ) As FlushConstrain
Regards
Alan
haphanthanhtam.work
hi @A.Acheson
how do you fix it
it's worst
A.Acheson
If you replace the letter "P" with "F" this should fix that method. The error message states you have the wrong method.
Fixed:
mate3 = asmDoc.ComponentDefinition.Constraints.AddFlushConstraint(face5, face6, 0)
Regards
Alan
haphanthanhtam.work
thank you !!!😅
