Get a centerpoint on the centermark, when projection a circular geometry
cco2JFB7
cco2JFB7
Do any have an idea of a rule that will put a center point on the center mark, when projection of a circular geometry?
I have looked for a snippet but without any luck
Christian
A.Acheson
Hi @cco2JFB7
I don't have a sample at hand but this sample here might give you some help.
Regards
Alan
A.Acheson
Hi @cco2JFB7
Here is a sample
  	Dim oPartDoc As PartDocument = ThisDoc.Document
	'  Reference to the component definition.
	Dim compDef As PartComponentDefinition = oPartDoc.ComponentDefinition
	' Get the sketch we want to use.
	Dim sketch As PlanarSketch = compDef.Sketches(2)
	sketch.edit
	' Prompt user to select an edge.
	Dim cirEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select an edge")
	' Add the circles edge to the sketch by projecting.
	Dim sketchCirc As SketchCircle = sketch.AddByProjectingEntity(cirEdge)
	' Get centerpoint as SketchPoint.
	Dim cirSketchPoint As SketchPoint = sketchCirc.CenterSketchPoint
	' Convert the Sketchpoint to Hole Center.
	cirSketchPoint.HoleCenter = True
 	sketch.ExitEdit
Regards
Alan
