Create Geometry Intent for Drawing View on Spline min/max snap points - VBA
Hi to community.
For SPline curves PointIntentEnum definitions are not working ( I haven't find anything so far) for creating geometry intents relevant to snap points of min/max. On the figure below I need to find points like P1, P2 and P3 in order to create dimensions by code.
Drawing Curves Geometry IntentsDrawing Curves Geometry Intents
So I found some codes and adapt them to the purpose;
 This is the part of vba sub for dividing Splines in to multiple geometric intents:
Sub AddGI(ByRef oGeometryIntents() As GeometryIntent, oGeometryIntent As GeometryIntent)
    ReDim Preserve oGeometryIntents(UBound(oGeometryIntents) + 1)
    Set oGeometryIntents(UBound(oGeometryIntents)) = oGeometryIntent
End Sub
'Dim oGeometryIntents()  As GeometryIntent
    'Dim oGI                 As GeometryIntent
    'ReDim oGeometryIntents(0 To 0)
    'For Each oDrawingCurve In oDrawingView.DrawingCurves
        'Select Case oDrawingCurve.CurveType
            Case CurveTypeEnum.kBSplineCurve:
                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent)
                AddGI oGeometryIntents, oGI
                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent)
                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kMidPointIntent)
                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kCenterPointIntent)
                '' DIVIDE SPLINES
                Dim MinParam            As Double
                Dim MaxParam            As Double
                Call oDrawingCurve.Evaluator2D.GetParamExtents(MinParam, MaxParam)
                Dim i                   As Long
                Dim dblParams(0 To 0)   As Double
                Dim dblPointsCoord()    As Double
                Dim dblCoordinates()    As Double
                Dim NbrOfPoints As Long
                    NbrOfPoints = 25
                ReDim dblCoordinates(0 To NbrOfPoints, 1 To 2)
                For i = 0 To NbrOfPoints
                    dblParams(0) = MinParam + i * (MaxParam - MinParam) / NbrOfPoints
                    Call oDrawingCurve.Evaluator2D.GetPointAtParam(dblParams, dblPointsCoord)
                    dblCoordinates(i, 1) = dblPointsCoord(0)
                    dblCoordinates(i, 2) = dblPointsCoord(1)
                    Dim oPointOnSPlineCurve As Point2d
                    Set oPointOnSPlineCurve = ThisApplication.TransientGeometry.CreatePoint2d(dblPointsCoord(0), dblPointsCoord(1))
                    Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, oPointOnSPlineCurve)
                Next i
                '' END DIVIDE SPLINES
''They don't have any effect for spline curve
'                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kBottomRightPointIntent)
'                AddGI oGeometryIntents, oGI
'                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kBottomMiddlePointIntent)
'                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kBottomLeftPointIntent)
'                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kLeftMiddlePointIntent)
'                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kRightMiddlePointIntent)
'                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kTopLeftPointIntent)
'                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kTopMiddlePointIntent)
'                Set oGI = oDrawingView.Parent.CreateGeometryIntent(oDrawingCurve, PointIntentEnum.kTopRightPointIntent)
            Case CurveTypeEnum.kUnknownCurve:
                MsgBox ("Unknown") 'reserved for later
            Case Else:
        End Select
    Next oDrawingCurve
SPLINE MIN/MAX  approximationSPLINE MIN/MAX approximation
'Draw Intent Points
    Dim oDrawingSketchPoints As DrawingSketch
    Set oDrawingSketchPoints = oDrawingView.Sketches.Add
    oDrawingSketchPoints.name = "Sketch Points"
    oDrawingSketchPoints.Edit
    'Dim i As Integer
    For i = 1 To UBound(oGeometryIntents)
        Dim oSketchCircle As SketchCircle
        If Not oGeometryIntents(i).PointOnSheet Is Nothing Then
            Set oSketchCircle = oDrawingSketchPoints.SketchCircles.AddByCenterRadius(oDrawingSketchPoints.SheetToSketchSpace(oGeometryIntents(i).PointOnSheet), 0.1)
            oSketchCircle.LineWeight = 0.1
            oSketchCircle.OverrideColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
        End If
    Next i
    oDrawingSketchPoints.ExitEdit
Is there any convenience way to find these min/max snap points of SPlines using VBA?
Thanks in advance.
YuhanZhang
Unfortunately now the API still does not support to get the quadrantal points(left/right/top/bottom most points) on BSpline drawing curves for creating dimensions, please log this wish to IdeaStation that we will consider it. If you can add comment to provide more info may help us to evaluate it.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Thank you for helping me several times.
Regards.
SašoPrijatelj
I'm also trying to implement this. Is it possible with Inventor 2022?
Sašo
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
YuhanZhang
We do have a story(INVGEN-28734) to track this requirement, but unfortunately this was not scheduled for Inventor 2022. We do will consider this in the future.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
m_baczewski
Maybe someone has found a way to find the Max and Min points for spline elements? The RangeBox for this type of curve is larger than one might expect."
