Create files with iLogic
Neil_Cross
Mentor Mentor
Neil_Cross
Does anyone have any old code which they could kindly share which does something remotely close to the following:
I want an iLogic dialog box/form which will create an assembly structure of new files.
The new files created will use a numbering scheme from Vault.
User can specify how many sub levels are in there.
Option to input iProperty description during the process.
i.e. Give me a new assembly with 12 sub-assemblies, and it will create the empty physical files like this...
Anything remotely close to that would be a great start
Thanks very much,
Neil
AlexFielder
Simply put, yes. Kind of:
An old project I worked on provided us with pdf files of legacy drawings and a spreadsheet of the metadata associated with each. I wrote a tool which populated a top-level assembly with the child (Part/Assembly) documents as placeholder "disks".
After getting annoyed with having to manually replace the "disks" with previously vaulted files, I integrated it with Vault Professional so that (as we built a library of legacy parts) the tool would pull down previous work.
Is that similar to what you need?
AlexFielder
Hi @Neil_Cross
I know you've either solved this by now or thrown in the towel on it but I just stumbled across these rules:
https://github.com/koechlm/iLogic-Vault/tree/master/iLogic-Vault-QuickstartLibrary/Sample%20Rules%20...
I notice it requires a custom .dll for reasons unknown but the logic is sound otherwise. Perhaps @Markus.Koechl can explain what QuickstartiLogicLibrary.dll does beyond using the default Vault .dlls?  Scratch that, it seems QuickstartiLogicLibrary.dll adds a wrapper around the standard Vault API that makes it easier to work with and retrieve files from Vault.
Markus.Koechl
I confirm that the library mentioned is a wrapper to share Vault API commands in "iLogic" syntax. In other words, to use an iLogic command "AddFile" or "Component.Add" a local file is expected.
Go to the download section as there are PowerPoint documentation, sample codes for each library function and also snippets for fast coding.
To retrieve numbers is not part of the library yet, but #1 priority for the next update early April time frame.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
idealogicERZYZ
I have a problem installing the package. Errors attached. I have Windows 7 Prof and Inventor PL. I can ask for help.
Szczegółowe informacje na temat wywoływania debugowania w trybie JIT (just in time)
zamiast tego okna dialogowego znajdują się na końcu tego komunikatu.
************** Tekst wyjątku **************
System.InvalidOperationException: Dokument XML zawiera błąd (2, 2). ---> System.InvalidOperationException: Nie oczekiwano elementu <doc xmlns=''>.
w Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderCodeSnippets.Read4_CodeSnippets()
--- Koniec śladu stosu wyjątków wewnętrznych ---
w System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
w System.Xml.Serialization.XmlSerializer.Deserialize(TextReader textReader)
w iLogic.CodeSnippetsRead.ReadXML(String fileName)
w iLogic.CodeSnippetsTree.MergeFile(String fileName)
w iLogic.Controls.CustomSnippetsControl.OpenAndMergeSnippetsFile()
w DevExpress.XtraBars.BarItem.OnClick(BarItemLink link)
w DevExpress.XtraBars.BarButtonItem.OnClick(BarItemLink link)
w DevExpress.XtraBars.BarItemLink.OnLinkClick()
w DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
w DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
w DevExpress.XtraBars.Controls.CustomLinksControl.OnMouseUp(MouseEventArgs e)
w System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
w System.Windows.Forms.Control.WndProc(Message& m)
w DevExpress.XtraBars.Controls.DockedBarControl.WndProc(Message& msg)
w System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Zestawy załadowane **************
mscorlib
Wersja zestawu: 4.0.0.0
Wersja Win32: 4.7.3416.0 built by: NET472REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
WpfHost
Wersja zestawu: 0.0.0.0
Wersja Win32: 24, 10, 23900, 0000
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202020/Bin/WpfHost.DLL
System
Wersja Win32: 4.7.3451.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
InvIPC
Wersja zestawu: 24.10.23900.0
Wersja Win32: 24.10.23900.0000
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202020/Bin/InvIPC.DLL
System.Core
Wersja Win32: 4.7.3429.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
InvUIModelBrowser
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202020/Bin/InvUIModelBrowser.DLL
etc. the rest of the errors in the attachment
E
