iLogic - Colour Parts in Assembly
I'm looking to change the part appearances at assembly level via a excel spreadsheet.
The current code I've got works fine for a individual part. However, there is over 100 panels per assembly.
How do I make the code Loop/Catch/Map/For Each through the range of the 100+ excel entries?
TEST = GoExcel.CellValue("C:\Users\person\Documents\Book1.xlsx", "Sheet1", "C2")
TEST_2 = GoExcel.CellValue("C:\Users\person\Documents\Book1.xlsx", "Sheet1", "D2")
Component.Color(TEST & ":1") = TEST_2
TEST = Browser part name in assembly
TEST_2 = Colour/Appearance name required for assembly.
Cheers
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that below blog article link may be helpful.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2018/ENU/Inventor-API/files/SetOccurrenceAppearance-Sample-htm.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
