Create derive file from active assembly or active part
k14348
k14348
Sub CreateDerivedPart()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2015\Templates\English\Standard (in).ipt", True)
Dim oPartDef As PartComponentDefinition
Set oPartDef = oPartDoc.ComponentDefinition
Dim oRefComp As ReferenceComponents
Set oRefComp = oPartDef.ReferenceComponents
Dim oDerAsmComp As DerivedAssemblyDefinition
Set oDerAsmComp = oRefComp.DerivedAssemblyComponents.CreateDefinition(oAsmDoc.FullDocumentName)
oDerAsmComp.DeriveStyle = kDeriveAsMultipleBodies
oDerAsmComp.IncludeAllTopLevelWorkFeatures = kDerivedExcludeAll
oDerAsmComp.IncludeAllTopLevelSketches = kDerivedExcludeAll
oDerAsmComp.IncludeAllTopLevelParameters = kDerivedExcludeAll
oDerAsmComp.IncludeAllTopLeveliMateDefinitions = kDerivedExcludeAll
oDerAsmComp.DeriveStyle = kDeriveAsSingleBodyNoSeams
Call oDerAsmComp.SetHolePatchingOptions(kDerivedPatchNone)
Call oDerAsmComp.SetRemoveByVisibilityOptions(kDerivedRemoveNone)
Dim oDerAsm As DerivedAssemblyComponent
Set oDerAsm = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerAsmComp)
Call oDerAsm.SuppressLinkToFile
End Sub
Please help me to solve this error.
-karthik
HermJan.Otterman
this will only work with an assembly, because the say that the active document is an assembly...
the last line is missing "= true" or "= false"
maybe you allso need to delete the call... I tested it in VB.net, not in VBA...
but the line  Call oDerAsm.SuppressLinkToFile  gives or sets a boolean
so:
oDerAsm.SuppressLinkToFile = False
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
