I would lyk to create Derive component from active assembly or active partfile
k14348
k14348
Sub CreateDerivedPart()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2015\Templates\English\Standard (in).ipt", True)
    Dim oPartDef As PartComponentDefinition
    Set oPartDef = oPartDoc.ComponentDefinition
    Dim oRefComp As ReferenceComponents
    Set oRefComp = oPartDef.ReferenceComponents
    Dim oDerAsmComp As DerivedAssemblyDefinition
    Set oDerAsmComp = oRefComp.DerivedAssemblyComponents.CreateDefinition(oAsmDoc.FullDocumentName)
    oDerAsmComp.DeriveStyle = kDeriveAsMultipleBodies
    oDerAsmComp.IncludeAllTopLevelWorkFeatures = kDerivedExcludeAll
    oDerAsmComp.IncludeAllTopLevelSketches = kDerivedExcludeAll
    oDerAsmComp.IncludeAllTopLevelParameters = kDerivedExcludeAll
    oDerAsmComp.IncludeAllTopLeveliMateDefinitions = kDerivedExcludeAll
    oDerAsmComp.DeriveStyle = kDeriveAsSingleBodyNoSeams
    Call oDerAsmComp.SetHolePatchingOptions(kDerivedPatchNone)
    Call oDerAsmComp.SetRemoveByVisibilityOptions(kDerivedRemoveNone)
    Dim oDerAsm As DerivedAssemblyComponent
    Set oDerAsm = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerAsmComp)
    Call oDerAsm.SuppressLinkToFile
End Sub
Please help me to solve error.
-karthik
HermJan.Otterman
better remove this one, because it is the same as the other question...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
