Create custom iProperty for subcomponents & subassemblies from within parent assembly
iogurt1
iogurt1
Hey everyone. Our goal is to create a new iProperty called "TEST" in just the first level of children of an assembly. With this code, it does what we want, but it goes all the way down, if there are subassemblies with parts in them. Is it possible to only run this on the top level items? Thanks!
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all Of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
		If iProperties.Value(oOccurrence.Name, "Status", "Status") = ""
	    iProperties.Value(oOccurrence.Name, "Custom", "TEST") = iProperties.Value(oOccurrence.Name, "Project", "Part Number") & iProperties.Value(oOccurrence.Name, "Project", "Revision Number")
	    Else
	    iProperties.Value(oOccurrence.Name, "Custom", "TEST") = iProperties.Value(oOccurrence.Name, "Project", "Part Number") & iProperties.Value(oOccurrence.Name, "Project", "Revision Number") & "_P" & iProperties.Value(oOccurrence.Name, "Status", "Status")
	    End If
Next
'auf .iam Ebene
		If iProperties.Value("Status", "Status") = ""
	    iProperties.Value("Custom", "TEST") = iProperties.Value("Project", "Part Number") & iProperties.Value("Project", "Revision Number")
	    Else
	    iProperties.Value("Custom", "TEST") = iProperties.Value("Project", "Part Number") & iProperties.Value("Project", "Revision Number") & "_P" & iProperties.Value("Status", "Status")
	    End If
JelteDeJong
you can try this:
Dim doc As AssemblyDocument = ThisDoc.Document
For Each oOccurrence As ComponentOccurrence In doc.ComponentDefinition.Occurrences
    If iProperties.Value(oOccurrence.Name, "Status", "Status") = "" Then
    Else
    End If
Next
'auf .iam Ebene
If iProperties.Value("Status", "Status") = "" Then
Else
End If
Jelte de Jong
Blog: hjalte.nl - github.com
iogurt1
Thanks @JelteDeJong, works perfectly now!
