Window select project geometry
mat_hijs
mat_hijs
Does anyone happen to have some code that allows me to project geometry using window selection? I want to project a lot of lines from one sketch to another which is quite tedious when I have to click each line separately. Especially because these lines are all on top of construction lines that I don't want to project. But this means I have to use select other half of the time.
JelteDeJong
you can try this. Run this rule. Select the original sketch in your browser then select the target sketch in your browser. An watch the magic...
Dim doc As PartDocument = ThisDoc.Document
Dim orgSketch As PlanarSketch = ThisApplication.CommandManager.
	Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select original sketch")
Dim newSketch As PlanarSketch = ThisApplication.CommandManager.
	Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select new sketch")
For Each ent As SketchEntity In orgSketch.SketchEntities
    If ent.Construction Then Continue For
    If ent.Type = ObjectTypeEnum.kSketchPointObject Then Continue For
    newSketch.AddByProjectingEntity(ent)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
mat_hijs
I don't need to project every line that is not a construction line, but this seems to work and deleting projected lines that I don't need is a lot faster than projecting them one by one since this can be done with window selection.
Thank you very much!
Yijiang.Cai
It has been implemented in 2023.2, and you could more information in the page. Thanks!
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
