Create Copy with ilogic
jam_bhatti
Message 1 of 24
jam_bhatti
I have done a Vessel Nozzle with options as sub assembly and need to create a clone at same location with all constraints.
is it possible by ilogic rule.
mean just click copy button on form and create same nozzle at current spot. then i move to another locations to create other nozzle with different sizes.
Replies (23)
Message 21 of 24
P_Korgaonkar
Hello Guys
I am very new to Ilogis, trying to learn and do the same as what Jamil is trying.
I have created an assembly of conveyor, and need to use it in layout with different part numbers, with different variations in size and sahpe and so on.
I have managed to create an assembly which works the way I need, but now stuck on making copy with new part numbers.
If I copy this code and create the rule, will it just copy my assembly?
I just tried it and got this error.
Not sure what to do.
Message 22 of 24
P_Korgaonkar
Hello There
My assembly consist of parts as per screen shot below.
I need to rename parts by replacing IL Cxxx by C4012 and then C4013 and so on.
Please help.
Thanks in Advance
Regards
Parag
Message 23 of 24
MechMachineMan
Have you ever used iLogi design copy from the ribbon when all documents are
closed?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 24 of 24
P_Korgaonkar
Thanks MechMachine,
Yes, I have tried that, If this works, it would save lot of time.
This code looks a bit complex to me
I am able to use Ilogic snippets to get my designs work, most of it is "if and else if" statements.
where can I learn this kind of code, does it come under VB.net or VBA or something else?
Regards
Parag
