create an imate based on a work point in the first sub assembly
Hi all,
i was wondering if someone would be able to help me, i am after a little bit of code to get the work points from the first sub-assembly and if a work point is called = "something" then in the top level add a mate iMate called "something" at that work point.
i have had a look around and found a few bits of code but i have not been able to figure this out.
Thanks in advance for any help
Chris
this is what i have at the moment so.
i can get the work point i want in the sub-assembly (WP) and i can get its x,y,z points (WP.Point)
but i cant work out how to make an iMate in the top assembly on that WorkPoint?
can anyone help ?
Public Sub getpoint()
        'Define the Document
        Dim ThisApplication As Inventor.Application
        ThisApplication = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Dim oDoc As AssemblyDocument
        oDoc = ThisApplication.ActiveDocument
        Dim tankAsmComp As AssemblyComponentDefinition
        tankAsmComp = oDoc.ComponentDefinition
        ' Get the referenced assembly.
        ' Dim tankAsm As AssemblyDocument = drawView.ReferencedDocumentDescriptor.ReferencedDocument
        'Dim tankAsmComp As AssemblyComponentDefinition = tankAsm.ComponentDefinition
        ' Get the occurrence of the tank in the assembly.
        Dim tankOcc As ComponentOccurrence = tankAsmComp.Occurrences.Item(1)
        ' Get the tank part.
        Dim tankPartComp As AssemblyComponentDefinition = tankOcc.Definition
        ' Get the work point named "TANKWP".
        Dim WP As WorkPoint
        For Each WP In tankPartComp.WorkPoints
            If WP.Name = "Center Point" Then
                'WP.Point
                Dim oMateiMateDefinition As MateiMateDefinition
                oMateiMateDefinition = tankAsmComp.iMateDefinitions.AddMateiMateDefinition(tankOcc, 0, InferredTypeEnum.kInferredPoint, WP.Point, "test")
                'oMateiMateDefinition = tankAsmComp.iMateDefinitions.AddMateiMateDefinition(WP, 0, InferredTypeEnum.kInferredPoint, WP.Point, "test")
            End If
        Next
    End Sub
JelteDeJong
You need to create a WorkPointProxy and use that to create the iMate. Some thing like this.
Dim centerPoint As WorkPoint = Nothing
For Each WP As WorkPoint In tankPartComp.WorkPoints
        centerPoint = WP
    End If
Next
' create WorkPointProxy
Dim centerPointProxy As Inventor.WorkPointProxy = Nothing
tankOcc.CreateGeometryProxy(centerPoint, centerPointProxy)
' create iMate with the WorkPointProxy
oMateiMateDefinition = tankAsmComp.iMateDefinitions.AddMateiMateDefinition(centerPointProxy, 0, InferredTypeEnum.kInferredPoint, , "test")
Jelte de Jong
Blog: hjalte.nl - github.com
hi JelteDeJong
thank you, I have just been working it and have come to the same method of working.
I have marked your solution as accepted because it is a lot neater than what I have.
thank you for your help.
Kind Regards
