Running an External Rule for All Sub Parts and Parts under Subassemblies
Message 1 of 10
I want to run an external rule for all part from top to bottom. I have found a code in the forum but it is working only for top assembly.
Can you help me about this ?
Sub Main()
    Dim oDoc As Document
    oDoc = ThisApplication.ActiveDocument
    Call Adding(oDoc.ComponentDefinition.Occurrences, 0)
End Sub
Sub Adding(Occurrences As ComponentOccurrences, _
                             Level As Integer)
    Dim oOcc As ComponentOccurrence
iLogicVb.RunExternalRule("deneme2")
For Each oOcc In Occurrences
     'If it is an Assembly go to next Level
     If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
      	Call Adding(oOcc.SubOccurrences, Level + 1)
     Else
Next
End Sub
Replies (9)
Message 2 of 10
JelteDeJong
At first glance i don't see strange things in your code, it should find all parts. But i wonder how your iLogic code "deneme2" knows which occurrence (or part) it should use....
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 10
deneme2 code is something like this ( a lot of try catch):
	Dim PropertyName1 As String = "CHardness"
	Dim propertyValue As String = ""
	customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
	Try
	      prop = customPropertySet.Item(PropertyName1)
	Catch
	      customPropertySet.Add("", PropertyName1)
		  iProperties.Value("Custom", PropertyName1) = propertyValue
	End Try
Message 4 of 10
This works for me for user parameters but custom parameters won't work. I think other code should be modified.
'Define the open document
oDoc = ThisDoc.Document
'Dim oDoc As AssemblyDocument
'oDoc = ThisApplication.ActiveDocument
If Not ThisApplication.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
	Return
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In oDoc.AllReferencedDocuments
ThisApplication.Documents.Open(docFile.FullFileName, True)
docFile.Save
docFile.Close
Next
iLogicVb.UpdateWhenDone = True
deneme2 rule:
	Try
	Catch
	End Try
			oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
				'Setting an userParameter as text parameter
				Try
					oMyParameter("Mass1") = Parameter("Mass1")
					Catch
				oParameter = oMyParameter.AddByValue("Mass1", "", UnitsTypeEnum.kTextUnits)
			End Try
				oParameter = oMyParameter.AddByValue("Material1", "", UnitsTypeEnum.kTextUnits)
				oParameter = oMyParameter.AddByValue("SDef1", "", UnitsTypeEnum.kTextUnits)
				oParameter = oMyParameter.AddByValue("SDef2", "", UnitsTypeEnum.kTextUnits)
				oParameter = oMyParameter.AddByValue("SDef3", "", UnitsTypeEnum.kTextUnits)
				oParameter = oMyParameter.AddByValue("SDef4", "", UnitsTypeEnum.kTextUnits)
Parameter.UpdateAfterChange = True
iLogicVb.RunExternalRule("StokTanım")
iLogicVb.RunExternalRule("Alan")
iProperties.Value("Custom", "StockNo_2") = iProperties.Value("Project", "Authority")
iProperties.Value("Custom", "StockNo_3") = iProperties.Value("Summary", "Category")
iProperties.Value("Custom", "Quantity") = iProperties.Value("Project", "WEB LINK")
iProperties.Value("Status", "Checked By") = iProperties.Value("Summary", "Manager")
iProperties.Value("Summary", "Manager") = "Mehmet Evrenosoğlu"
	Try
	iProperties.Value("Custom", "Title_2") = iProperties.Value("Summary", "Company")
	Catch
	End Try
	Try
	iProperties.Value("Custom", "Subject_2") = iProperties.Value("Custom", "ASSM.NAME")
	Catch
	End Try
 Kindly ask for your help.
Message 5 of 10
J-Camper
I played around a bit with your code, and I think this will work:
Main Code:
Sub Main()
    'Make sure rule is running in Assembly Document.  Not needed if rule is stored locally in assembly file.
	If ThisDoc.Document.DocumentType <> kAssemblyDocumentObject
		Exit Sub
	Dim oRefDoc As Document
	'Look at all documents referenced in this assembly
	For Each oRefDoc In oDoc.AllReferencedDocuments
		'Only looking for part documents that are modifiable
 		If oRefDoc.DocumentType = kPartDocumentObject And oRefDoc.IsModifiable = "True"
			Call RunPartDocuments(oRefDoc)
	Next
End Sub
Sub RunPartDocuments(PassDoc As PartDocument)
Dim refPartDoc As PartDocument = ThisApplication.Documents.Open(PassDoc.FullFileName, True)
refPartDoc.Save2()
refPartDoc.Close
End Sub
External Rule Code:
Sub Main
'Make sure document is a Part Document
If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject
	MessageBox.Show("This Document is not a part document, but this rule is set up only to work with Part Documents.", "Canceling Rule")
	Exit Sub
'Access Custom iProperties, and create missing Properties
customPropertySet = ThisApplication.ActiveDocument.PropertySets.Item("Inventor User Defined Properties")
Dim PropertyName As String()
Dim propertyValue As String()
PropertyName= {"CHardness", "StockNo_2", "StockNo_3", "Quantity", "Title_2", "Subject_2", "ASSM.NAME"}
propertyValue= {"testing", "Authority", "Category",        "1",    "Title",   "Subject",   "Parent"}
Dim i As Integer = 0
While i < PropertyName.Count
	Try
	      prop = customPropertySet.Item(PropertyName(i))
	Catch
	      customPropertySet.Add("", PropertyName(i))
		  customPropertySet.Item(PropertyName(i)).Value = propertyValue(i)
	End Try
	i = i+1
End While
'] Access Custom iProperties, and create missing Properties
'Access local UserParameters , and create missing Parameters
oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
Dim Parameters As String()
Parameters = {"Mass1", "Material1", "SDef1", "SDef2", "SDef3", "SDef4"}
Dim j As Integer = 0
While j < Parameters.Count
	Try
	  	Params = oMyParameter(Parameters(j)) ' Asking if this  Parameter exists
	Catch
		Params = oMyParameter.AddByValue(Parameters(j), "", UnitsTypeEnum.kTextUnits) ' If not create this parameter
	End Try
	j = j+1
End While
'] Access local UserParameters , and create missing Parameters
'Update mid-rule
'Run other External Rules
'iLogicVb.RunExternalRule("StokTanım")
'iLogicVb.RunExternalRule("Alan")
'Assuming the previous 2 rules will modify Property values, and setting thsoe values:
customPropertySet.Item("StockNo_2").Value = ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Authority").Value
customPropertySet.Item("StockNo_3").Value = ThisApplication.ActiveDocument.PropertySets.Item("Inventor Document Summary Information").Item("Category").Value
customPropertySet.Item("Quantity").Value = ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Catalog Web Link").Value
ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Checked By").Value = "Mehmet Evrenosoğlu"
ThisApplication.ActiveDocument.PropertySets.Item("Inventor Document Summary Information").Item("Manager").Value = "Mehmet Evrenosoğlu"
customPropertySet.Item("Title_2").Value = ThisApplication.ActiveDocument.PropertySets.Item("Inventor Document Summary Information").Item("Company").Value
customPropertySet.Item("Subject_2").Value = customPropertySet.Item("ASSM.NAME").Value
'Update When Done
End Sub
I don't know what the other two External rules within deneme2 do so they are commented out in the above code, but I assumed they updated iProperty Values set after them.
Also for your information I have attached an excel sheet with PropertySet Names and Their corresponding Properties.
Message 6 of 10
You are absoultly right. Thank you so much for your hard work !
Message 7 of 10
It is skipping assembly documents, is it possible to add assembly documents too ?
Message 8 of 10
J-Camper
It should be including all the parts within those assemblies with "AllReferencedDocuments".  but if you want to run the containing assemblies too, you can add an "Else If" statement where you are sifting through "AllReferencedDocuments":
   		Else If oRefDoc.DocumentType = kAssemblyDocumentObject And oRefDoc.IsModifiable = "True"
                        'Do Assembly stuff
	Next
If you plan to run the assemblies through the same External rule, I think the iProperties and User Parameters are mapped the same way so it should work.  You would need to modify the Document type check in the External rule:
'Make sure document is a Part or Assembly Document
If ThisApplication.ActiveDocument.DocumentType = kPartDocumentObject Or _
	'Continue
Else
	MessageBox.Show("This Document is not a Part or Assembly document, but this rule is set up only to work with Part Documents.", "Canceling Rule")
	Exit Sub
Although I still don't know what those other two External rules are doing. If you try to do more document type specific things, like looking at surfacebodies in a part or occurrences in an assembly, you definitely need to separate the External rule or you will get errors.
Or you can run a separate External rule for the Assembly documents, so that you can look at assembly document specific Objects and not modify your Part specific External rule.
Message 9 of 10
I reshape my rules, thanks to your contributions.
Here is my main rule:
RRFA=MessageBox.Show("Bu komutu çalıştırmadan önce tüm CHECKOUT'ları almış olmanız gerekmektedir. Eğer checkout almadıysanız lütfen işlemi iptal ederek checkout alın. Referans olarak çekilmiş .stp parçalar montajda var ise program hata verecektir. Devam edilsin mi?", "ÇOK ÖNEMLİ UYARI",MessageBoxButtons.YesNo,MessageBoxIcon.Warning)
If RRFA = vbYes Then
	RRFA2= MessageBox.Show("Tüm montaj için parametreleri eklemeye başlamak üzeresiniz. İşlem süresince Inventor'e müdahale etmeyiniz. Checkout'u sizde olmayan parçalar açıldıktan sonra kapanmayacaktır. Montajın büyüklüğüne göre işlem süresi çok uzun olabilir. Devam etmek istediğinize emin misiniz ?", "Köprüden Önceki Son Çıkış",MessageBoxButtons.YesNo,MessageBoxIcon.Warning)
If RRFA2 = vbYes Then
	Return
'iLogicVb.RunExternalRule("PCustomUser")
iLogicVb.RunExternalRule("RunRuleForAll2")
docFile.Save
docFile.Close
Next
	MessageBox.Show("İşlem tamamlandı.", "Mutlu Son")
	Else
	MessageBox.Show("İşlem iptal edildi.", "ÇOK ÖNEMLİ UYARI")
Else
 Here is second rule RunRuleForAll2
			'Msj= MessageBox.Show("Bu makroyu halihazırda mevcut olan TR-EN montaj ve partlar için çalıştırırsanız olmayan parametreler eklenir ve eski antetten yeni antete aktarım yapılır. Önceden tanımlanmış olanlar olduğu gibi kalır. Devam etmek istediğinize emin misiniz ?", "Son Karar",MessageBoxButtons.YesNo)
			'If Msj = vbYes Then
PropertyName = {"CHardness", "SHardness", "Hblack", "HGreen", "MRed", "MBlack", "SBlue","Quantity", "StockNo_2", "StockNo_3", "StockNo_4", "StockDef1", "StockDef2", "StockDef3", "StockDef4", "Quantity", "Title_2", "Subject_2"}
propertyValue= ""
Dim a As Integer = 0
While a < PropertyName.Count
	Try
	      prop = customPropertySet.Item(PropertyName(a))
	Catch
	      customPropertySet.Add("", PropertyName(a))
		  customPropertySet.Item(PropertyName(a)).Value = propertyValue
	End Try
	a = a+1
End While
			Dim PropertyName18 As String = "ToleranceClass"
			Dim propertyValue1 As String = "ISO 2768 CL"
			Try
			prop = customPropertySet.Item(PropertyName18)
			Catch
			customPropertySet.Add("", PropertyName18)
			iProperties.Value("Custom", PropertyName18) = propertyValue1
			End Try
			'Name=ThisApplication.ActiveDocument.FullDocumentName
		'	Dim name1 As String
		'name1=ThisDoc.FileName(True) 'without extension
		customPropertySet1 = ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties")
		customPropertySet2 = ThisApplication.ActiveDocument.PropertySets.Item("Document Summary Information")
			customPropertySet.Item("StockNo_2").Value = customPropertySet1.Item("Authority").Value
			customPropertySet.Item("StockNo_3").Value = customPropertySet2.Item("Category").Value
			customPropertySet.Item("Quantity").Value = customPropertySet1.Item("Catalog Web Link").Value
'KONTROL EDEN TANIMLAMA - TASARIMCININ APPLICATION OPTION'DAKI USER NAME'İNE GÖRE BELİRLEMEKTEDİR.
ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Designer").Value=ThisApplication.GeneralOptions.UserName
Dim Designer As String
Designer=ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Designer").Value
Dim Designers()={"Okan Murat", "Tayfun Ayyıldız", "Ömür Yıldırım", "Barış Kök", "Engin Oylukan", "Gençay Genç", "Hakan Gümüş", "Recep Başaran"}', "Mustafa Güner"}
Dim MaxCount As Integer
Dim Counter As Integer
i = 0
MaxCount = 7
For Counter=i To MaxCount
If Designer = Designers(i) Then
	ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Checked By").Value = "Recep Gümrük"
	Else
		ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Checked By").Value = "Zülkani Durmuş"
i = i + 1
Next
'KONTROL EDEN TANIMLAMA SON
			'Mevcutsa aktarım:
			'MessageBox.Show("Message", "Title")
			Try
			customPropertySet.Item("Title_2").Value = customPropertySet2.Item("Company").Value
			Catch
			End Try
			Try
			Catch
			End Try
			Dim ParamValue2 As Double = 0
			Dim ParamName2 = "Alan"
			Dim oDoc As Document = ThisApplication.ActiveDocument
			Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
			Dim oParams As Parameters = oCD.Parameters
			Dim oUserParams As UserParameters = oParams.UserParameters
			Try
			oParams(ParamName2).Value = ParamValue2
			Catch
			Dim newparam As UserParameter= oUserParams.AddByExpression(ParamName2, ParamValue2, "m^2")
			'oParams(ParamName2).Expression = iProperties.Area
			oParams(ParamName2).Value= iProperties.Area
			newparam.ExposedAsProperty=True
			'oParams.IsKey=True
			'oUserParams.AddByValue(ParamName,6,11270)
			End Try
Parameters = {"Mass", "Material", "SDef1", "SDef2", "SDef3", "SDef4"}
ParameterVal = {"", "", "", "", "", ""}
	Try
	Catch
		'Params.Iskey=True
	End Try
	j = j+1
End While
ThisDoc.Save
			'MessageBox.Show("Olmayan parametreler eklendi ve eski antetten yeni antete aktarım yapıldı. Her şey sen daha mutlu ol diye el birliği ile çalışıyor farkında mısın ?" & vbNewLine  & vbNewLine  & "STOK TANIMLAMALARINI DEĞİŞTİRMEYİ UNUTMA !!!", "Yaşıyorsun Şu Hayatı", MessageBoxButtons.OK)
			'MessageBox.Show("Stok tanımlamala", "Yaşıyorsun Şu Hayatı", MessageBoxButtons.OK)
ThisApplication.ActiveDocument.Save
			'Else
			'MessageBox.Show("İşlem iptal edildi.", "Peki...",MessageBoxButtons.OK)
			'End If
 Finally last Rule StokTanım:
oCustomPropertySet = ThisApplication.ActiveDocument.PropertySets.Item("Inventor User Defined Properties")
	MultiValue.SetList("SDef1", "",  "Stok Numarası Stock No", "Boyalı SN Painted SN", "Kaynaklı SN Welded SN", "Talaşlı SN Machining SN",
 "Kaplama SN Coating SN","Montaj SN Assembly SN")
MultiValue.SetList("SDef2", "",  "Stok Numarası Stock No", "Boyalı SN Painted SN", "Kaynaklı SN Welded SN", "Talaşlı SN Machining SN",
MultiValue.SetList("SDef3", "", "Stok Numarası Stock No", "Boyalı SN Painted SN", "Kaynaklı SN Welded SN", "Talaşlı SN Machining SN",
MultiValue.SetList("SDef4", "",  "Stok Numarası Stock No", "Boyalı SN Painted SN", "Kaynaklı SN Welded SN", "Talaşlı SN Machining SN",
oCustomPropertySet.Item("StockDef1").Value = oMyParameter("SDef1")
oCustomPropertySet.Item("StockDef2").Value = oMyParameter("SDef1")
oCustomPropertySet.Item("StockDef3").Value = oMyParameter("SDef2")
oCustomPropertySet.Item("StockDef4").Value = oMyParameter("SDef3")
'set custom property value
'iProperties.Value("Custom", "StockDef3") = Parameter.Value("SDef3")
'iProperties.Value("Custom", "StockDef4") =Parameter.Value("SDef4")
Parameter("Alan") = iProperties.Area
Parameter("Material") = iProperties.Material
Parameter("Mass")= iProperties.Mass
As you can guess i am getting errors.
Message 10 of 10
Michele_DeLucaSW7PJ
i get an errore on line 23:
