Create a workplane from a face in an assembly document
In an assembly document, I try to add a MateConstraint between male and female side of an 45 degres elbow.
The male side is built on the XZ Plane and Y Axis And I try to create a workplane on the female face.
But a got an error with the last line of code.  Here's my code (vb.net code) :
' Get application object
Dim app As Inventor.Application = GetObject(, "Inventor.Application")
Dim doc As Inventor.AssemblyDocument = app.ActiveDocument
' Get the selected occurrence
Dim occ As Inventor.ComponentOccurrence = doc.SelectSet.Item(1)
Dim body As Inventor.SurfaceBody = occ.SurfaceBodies(1)
' Get the face on female side
Dim face As Inventor.Face = body.Faces(58)
Dim params(3), normals(3) As Double
face.Evaluator.GetNormal(params, normals)
Dim vector As Inventor.Vector = app.TransientGeometry.CreateVector(normals(0), normals(1), normals(2))
Dim plane As Inventor.Plane = app.TransientGeometry.CreatePlane(face.PointOnFace, vector)
Dim workplane As Inventor.WorkPlane = doc.ComponentDefinition.WorkPlanes.AddByPlaneAndPoint(plane, face.PointOnFace, True)
Thank for help.
Pascal
leefsma
Hi
Comments from the API Help Files for method AddByPlaneAndPoint :
"This method is not currently supported when creating a work plane within an assembly"
In an assembly document only AddFixed method is supported. This is valid for all kind of wokfeatures.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
Thanks for your answer.
I've found a solution.  I didn't know that I could create constraint between FaceProxy and WorkPlaneProxy.
My solution:
Dim occ As Inventor.ComponentOccurrence = doc.ComponentDefinition.Occurrences(1)
Dim occ2 As Inventor.ComponentOccurrence = doc.ComponentDefinition.Occurrences(2)
Dim faceProxy As Inventor.FaceProxy = occ.SurfaceBodies(1).Faces(58)
Dim wp As Inventor.WorkPlane = occ2.Definition.WorkPlanes.Item("XZ Plane")
Dim wpProxy As Inventor.WorkPlaneProxy = Nothing
occ2.CreateGeometryProxy(wp, wpProxy)
doc.ComponentDefinition.Constraints.AddFlushConstraint(wpProxy, faceProxy, "0""")
Pascal
bravaiser
How to do the same for a part? And how to create a workplane from a selected face?
Thank you for the answer
