Create a form that can modify paramaters in an other part
jgomis.ext
jgomis.ext
Hi everyone !
I have create a "skeleton" part to build 2 parts that I have in an assembly.
In my skeleton part I only have sketchs and parameters that I  link in my two part to make them. And for finish I have made an assembly of these two parts.
I would like to create a form in my assembly to modify the parameters of my "skeleton" part and like that all my parts will be update in the same time.
But I don't know how to do it because my parameters are linked and I cannot modify them.
If someone could help me it will be verry verry cool 🙂
bradeneuropeArthur
can you Pack and Go the files in question?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JMGunnar
options 1
create forms in Assembly then update skeleton from Assembly
options 2
call forms from Assembly  with rule in skeleton "ShowForms"
see assembly
Luis_Pacheco_3D
Try this:
1. Create a rule in your assembly with this configuration.
Parameter("Skeleton_A:1", "Width") = Width
'Parameter skeleton = Form data
' Parameter Part1 = Parameter Skeleton
Parameter("Part1:1", "Width") = Parameter("Skeleton_A:1", "Width")
' Parameter Part2 = Parameter Skeleton
Parameter("Part2:1", "Width") = Parameter("Skeleton_A:1", "Width")
