Create a diameter dimension "dragged outside"
C-Hoppen
C-Hoppen
in Inventor a user can place a diameter dimension, terminate the command, grab the green center point and drag the dimension outside:
How can this be done by code?
A horizontal GeneralDimension with Intends kCircularLeftPointIntent and kCircularLeftPointIntent has no ø and doesn't work with with a circle through holes created by Centerlines.Add....
Christoph
aelqabbany
Give this a shot. You can add the ø symbol manually.
Dim oCircle As DrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select the circle you want to dimension")
Dim oDrawCurve As DrawingCurve = oCircle.Parent
Dim oView As DrawingView = oDrawCurve.Parent
Dim oSheet As Sheet = oView.Parent
Dim oDrawDoc As DrawingDocument = oSheet.Parent
Dim TextPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X, oView.Top - oView.Height - 2)
Dim RightCircleIntent As GeometryIntent = oSheet.CreateGeometryIntent(oDrawCurve,kCircularRightPointIntent)
Dim LeftCircleIntent As GeometryIntent = oSheet.CreateGeometryIntent(oDrawCurve,kCircularLeftPointIntent)
Dim x As LinearGeneralDimension = oSheet.DrawingDimensions.GeneralDimensions.AddLinear(TextPoint,RightCircleIntent,LeftCircleIntent)
x.Text.FormattedText = "Ø" & "<DimensionValue/>"
