ACAD block with centerlines
Kassenbouw
Kassenbouw
I want to insert my inventor drawings into Autocad. When opening the Inventor DWG in Autocad all the views are availeble as Blocks, without the centerlines. Is it possible to include the centerlines in these Autocad blocks through Ilogic?
When exporting to Acad DWG the centerlines are included but my views aren't blocks.
Thanks!
Kassenbouw
Does anyone have a solution for this problem?
theo.bot
I don't think there is an out of the box option. only the view geometry is a block in inventor DWG. In the documentation there are also no options available for the drawingview.insertinmodelspace
I think the quickest way is to export to autocad dwg and create a block within that file. Off course it requires rework for any update.
bradeneuropeArthur
Maybe you can create a new idea in the idea station for this.
If you insert the link I will vote.
parallel I will have a look to create a ACad block with centerline too.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
