Count visible selected type of drawing curve segment by any selectset
Message 1 of 9
Hi...
I want to count visible selected type of drawing curve segment by any selectset is activate in drawing view...
I get difficulties to  get the drawing view name (ex: "VIEW16") by activate selectset a drawing curve segment in that view...
The counting seem not found the correct answer... as below example... the part is actually having 2 size of fillet...
"Fillet1" x3 and Fillet2" x2 ... "Fillet1" visible count should be 2 in "VIWE16" but the result only count 1...
VBa.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSSet As SelectSet
Set oSSet = oDrawDoc.SelectSet
Dim oDwgCurveSegment As DrawingCurveSegment
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oView As DrawingView
Set oView = oSheet.DrawingViews.Item(1)
Dim i As Integer
For i = 1 To oView.DrawingCurves.Count
If oView.Name = "VIEW16" ThenFor Each oDwgCurveSegment In oView.DrawingCurves.Item(i).Segments
If oDwgCurveSegment.GeometryType = kCircularArcCurve2d Then
i = i + 1
MsgBox "kCircularArcCurve2d[" & i & "]"
End If
Next
End If
Replies (8)
Message 2 of 9
HideoYamada
I don't understand exactly what you want to do, but I have just rewritten your code.
Option Explicit
Sub test()
    Dim oSheet As Sheet
        Dim i As Integer
        Dim oDrawingCurve As DrawingCurve
        For Each oDrawingCurve In oView.DrawingCurves
            For Each oDwgCurveSegment In oDrawingCurve.Segments
                    i = i + 1
                End If
            Next oDwgCurveSegment
        Next oDrawingCurve
    End If
End Sub
Has this code approached what you want to do?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 9
Hi.
Please use my e-mail for this conversation.
The code is for my testing to approach what I actually need.
[ I need to count the visible "Fillet?" by one of it curve segments
selectset in it view (ex:VIEW16). To get the name VIEW16 by curve segment
selectset also I still struggle and not yet figure out how.]
Message 4 of 9
Hi…
Please use my e-mail for this conversation…
The code is for my testing to approach what I actually need…
[ I need to count the visible “Fillet?” by one of it curve segments selectset in it view (ex:VIEW16)… To get the name VIEW16 by curve segment selectset also I still struggle and not yet figure out how…]
Message 5 of 9
HideoYamada
O.K. Send the mail or private message to me freely.
Sub test2()
    Dim oDrawingCurveSegment As DrawingCurveSegment
    Dim oDrawingView As DrawingView
    Set oDrawingCurveSegment = ThisApplication.ActiveDocument.SelectSet(1)
    Set oDrawingView = oDrawingCurveSegment.Parent.Parent
    Debug.Print oDrawingView.Name
End Sub
The parent of the parent of the DrawingCurveSegment is DrawingView.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 6 of 9
I manage to get the drawing view name as your suggest... but I still having error for below sample to get the counting result as I need ...
Public Sub FilletLeader()
Dim oSheet As Sheet
Dim oFeatureName As String
Dim oFace As Face
Dim i As Integer
Dim RadiusDim As RadiusGeneralDimension
Set RadiusDim = oSSet(1)
Set oView = RadiusDim.Intent.Geometry.Parent
Set oDwgCurveSegment = RadiusDim.Intent.Geometry.Segments(1)
Set oFace = RadiusDim.Intent.Geometry.ModelGeometry.Faces(2)
oFeatureName = oFace.CreatedByFeature.Name
If oFace.CreatedByFeature.Faces.Item.CreatedByFeature.Name = oFeatureName Then
i = i + 1
MsgBox oFeatureName & " = " & i
End If
Next
Message 7 of 9
HideoYamada
This code will count the fillet curves that the feature is selected by the radius dimension and are shown as an arc in the view.
    ' Check the condition and initialize the values.
    If Not TypeOf ThisApplication.ActiveDocument Is DrawingDocument Then Exit Sub
    Dim oDrawDoc As DrawingDocument: Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet: Set oSheet = oDrawDoc.ActiveSheet
    If oSheet Is Nothing Then Exit Sub
    Dim oSSet As SelectSet: Set oSSet = oDrawDoc.SelectSet
    If oSSet.count < 1 Then Exit Sub
    If Not TypeOf oSSet(1) Is RadiusGeneralDimension Then Exit Sub
    Dim oRadiusDim As RadiusGeneralDimension: Set oRadiusDim = oSSet(1)
    Dim oFilletFeature As FilletFeature
    Dim oFace As Face
    For Each oFace In oRadiusDim.Intent.Geometry.ModelGeometry.Faces
        If TypeOf oFace.CreatedByFeature Is FilletFeature Then
            Set oFilletFeature = oFace.CreatedByFeature
            Exit For
        End If
    Next oFace
    If oFilletFeature Is Nothing Then Exit Sub
'    Debug.Print oFilletFeature.Name
    ' Prepare for counting the fillet edges
    Dim oView As DrawingView: Set oView = oRadiusDim.Intent.Geometry.Parent
    Dim NofFilletFaces As Integer
    NofFilletFaces = oFilletFeature.Faces.count
    Dim counted() As Boolean: ReDim counted(NofFilletFaces)
    Dim count As Integer
    Dim i As Integer
    ' Count fillet edges.
    Dim oDwgCurve As DrawingCurve
    For Each oDwgCurve In oView.DrawingCurves
        ' Only count if the edge is shown as an arc.
        If TypeOf oDwgCurve.Segments(1).Geometry Is Arc2d Then
            For Each oFace In oDwgCurve.ModelGeometry.Faces
                If oFace.CreatedByFeature Is oFilletFeature Then
                    ' Only count one time for each fillet face.
                    For i = 1 To NofFilletFaces
                        If oFilletFeature.Faces(i) = oFace And (Not counted(i)) Then
                            counted(i) = True
                            count = count + 1
                            Exit For
                        End If
                    Next i
                End If
                If count = NofFilletFaces Then Exit For
            Next oFace
        End If
    Next oDwgCurve
    Debug.Print count
End Sub
I think that this code works as you want.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 8 of 9
Thank you so much... May be I still need your help next time...
Message 9 of 9
Hi... I try the same method for count the "Chamfer1" in a View.... but can't figure out the curve segment like Fillet... Anything you can do about it...
