Count Inspection Dimensions for use in custom inspection dim table
Message 1 of 12
I'm in the process of writing VBA/iLogic for creating a custom inspection dimension table to be placed on a drawing.  I've been able to get the inspection dimensions data and fill in the table, but want to limit the table rows to the number of inspection dimensions.  Right now the code counts the number of general dimenions and the custom table uses the number of general dimensions to create the number of table rows.  (The Count property only appears to be included for DrawingDimensions, General Dimensions, and other dimension collections, but not inspection dimensions, because there is no collection for them.)  So this count results in empty table rows if the general dimension is not an inspection dimension.  I've also tried to delete rows that are empty without success.  And I've also looked into creating an InspectionDimensions class or collection to include a Count property, but I have limited knowledge of how this is done.  So, what is the best way to limit the table rows to only the number of inspection dimensions in the drawing and that I'm listing in the table?  Thank you!
Public Sub CreateInspectionDimsTable()
    ' Set a reference to the drawing document.
    oDocType = ThisApplication.ActiveDocumentType
    If oDocType <> kDrawingDocumentObject Then
        MsgBox "This is not a drawing document." + vbCrLf + "Please open a drawing document.", vbOKOnly, "Drawing Document Error"
        Exit Sub
    End If
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    If oSheet.CustomTables.Count > 0 Then
            oSheet.CustomTables.Item(1).Delete
    End If
    'Set the column titles & Create the custom table
    Dim oInspTblTitle As String
    oInspTblTitle = "INSPECTION DIMENSIONS"
    Dim oTitles(1 To 3) As String
    oTitles(1) = "DIMENSION NUMBER"
    oTitles(2) = "DESIGN"
    oTitles(3) = "ACTUAL"
    oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.125
    oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.ColumnValueHorizontalJustification = kAlignTextCenter
    oGenDimCount = oSheet.DrawingDimensions.GeneralDimensions.Count
    Debug.Print "General Dims Count = " + CStr(oGenDimCount)
    Debug.Print "Drawing Dims Count = " + CStr(oSheet.DrawingDimensions.Count)
    Debug.Print "Inspection Dims Count = " + "?"
    Dim oInspDimTable As CustomTable
    Set oInspDimTable = oSheet.CustomTables.Add(oInspTblTitle, ThisApplication.TransientGeometry.CreatePoint2d(1.5, 27), 3, oGenDimCount, oTitles)
    'Get Inspection Dimension Data
    Dim oInspDim As DrawingDimension
    Dim oInspDimShape As InspectionDimensionShapeEnum
    Dim oInspDimText As DimensionText
    Dim oInspDimText2 As Variant
    Dim oInspDimNumber As String
    Dim oInspDimRate As String
    Dim i As Integer
    Dim oCellInspDimNum As Cell
    Dim oCellInspDim As Cell
    i = 1
    For Each oSheet In oDrawDoc.Sheets
        For Each oInspDim In oSheet.DrawingDimensions
            If oInspDim.IsInspectionDimension Then
                oInspDim.GetInspectionDimensionData oInspDimShape, oInspDimNumber, oInspDimRate
                Set oInspDimText = oInspDim.Text
                oInspDimText2 = ThisApplication.UnitsOfMeasure.GetPreciseStringFromValue(oInspDim.ModelValue, kInchLengthUnits)
                Debug.Print oInspDimNumber
                Debug.Print oInspDimText.Text
                Debug.Print oInspDimText2
                Debug.Print ""
                Set oCellInspDimNum = oInspDimTable.Rows.Item(i).Item("DIMENSION NUMBER")
                oCellInspDimNum.Value = oInspDimNumber
                Set oCellInspDim = oInspDimTable.Rows.Item(i).Item("DESIGN")
                oCellInspDim.Value = oInspDimText2
                i = i + 1
            End If
        Next
    Next
    oInspDimTable.Sort "DIMENSION NUMBER", True
    Dim oRow As Row
    For Each oRow In oInspDimTable.Rows
        If oCellInspDimNum.Value <> oInspDimNumber Then
            oRow.Delete
        End If
    Next
End Sub
Replies (11)
Message 2 of 12
rjay75
Replace
with
    oGenDimCount = 0
    Dim oDim As DrawingDimension
    For Each oDim In oSheet.DrawingDimensions
            oGenDimCount = oGenDimCount + 1
        End If
    Next
This will go through the list Dimensions counting the Inspection Dimensions.
Message 3 of 12
I've been looking around for something like this, but upon using it, there were several coding errors. Most I have been able to fix, but i'm getting six errors for "'Let' and 'Set' assignment statements are no longer supported."
Anybody know what I need to change these to? Been looking around, cannot find anything on Let and Set.
FYI, I am using Inventor 2015
Message 4 of 12
BrandonBG
'Let' and 'Set' are used in VBA but not iLogic. The code above is VBA. Check the 'Straight VBA code' in the iLogic Rule Editor and it may work with some help. Otherwise, drop it in your inventor.ivb.
If you want to try to get this to operate, I was able to run the following and get it to work for my needs. I cobbled this together from several other threads on the board, and as you can see, it lacks a little efficiency.
Dim oDrawingDocument As DrawingDocument
oDrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDocument.ActiveSheet
Dim oCustomTable As CustomTable
Dim oCustomTables As CustomTables
oCustomTables = oSheet.CustomTables
For Each oCustomTable In oCustomTables
	If oCustomTable.Title = "FIELD VERIFICATION DIMENSIONS" Then
	oCustomTable.Delete()
	End If
Next
Dim oInspectionDimension As DrawingDimension
Dim oInspectionDimensionShape As InspectionDimensionShapeEnum
Dim oInspectionDimensionText As DimensionText
Dim oInspectionDimensionString As String
Dim oCellInspectionDimensionItem As Cell
Dim oCellInspectionDimension As Cell
Dim oInspectionDimensionCount As Integer
oInspectionDimensionCount = 0
For Each oInspectionDimension In oSheet.DrawingDimensions
	If oInspectionDimension.IsInspectionDimension Then
	oInspectionDimensionCount = oInspectionDimensionCount + 1
	End If
Next
Dim oColumnTitle(0 To 3) As String
oColumnTitle(0) = "Column1"
oColumnTitle(1) = "Column2"
oColumnTitle(2) = "Column3"
oColumnTitle(3) = "Column4"
Dim oActiveTableStyle As TableStyle
Dim oTableTitle As String
oActiveTableStyle = oDrawingDocument.StylesManager.TableStyles("**THE NAME OF YOUR TABLE STYLE**")
oTableTitle = oActiveTableStyle.Title
Dim oFieldVerificationTable As CustomTable
oFieldVerificationTable = oSheet.CustomTables.Add(oTableTitle, ThisApplication.TransientGeometry.CreatePoint2d(.635, oSheet.Height-.635), 4, oInspectionDimensionCount, oColumnTitle)
Dim oInspectionDimensionCount2 As Integer
oInspectionDimensionCount2 = 0
	oInspectionDimensionCount2 = oInspectionDimensionCount2 + 1
	oInspectionDimensionText = oInspectionDimension.Text
	oInspectionDimensionString = oInspectionDimensionText.Text
	oCellInspectionDimensionItem = oFieldVerificationTable.Rows.Item(oInspectionDimensionCount2).Item("Column1")
	oCellInspectionDimensionItem.Value = oInspectionDimensionCount2
	oCellInspectionDimension = oFieldVerificationTable.Rows.Item(oInspectionDimensionCount2).Item("Column2")
	oCellInspectionDimension.Value = oInspectionDimensionString + "''"
	End If
Next
oFieldVerificationTable.Style = oActiveTableStyle
iLogicVb.UpdateWhenDone = True
BrandonBG
Inventor 2015
Message 5 of 12
Thanks, but for some reason I still get an error with your suggestion: "The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
Message 6 of 12
BrandonBG
Make sure you change the code to match your Table Styles:
oActiveTableStyle = oDrawingDocument.StylesManager.TableStyles("!!!***HERE****!!!")
If the rule can't find it, it will spit out an error. Working with Table Styles is not the most straightforward process. I had to declare the Active TableStyle, then make a table, and then apply the Style to the new table.
BrandonBG
Message 7 of 12
I have been searching for this code from past couple of days.
Finally, got it.
Thanks to you for posting a code.
As mentioned, we need to mention table style to run the code, otherwise it will show error message.
I had tried it, but still I am getting error message.
Please let me know, how to fix this.
Message 8 of 12
BrandonBG
What error message are you receiving? Brandon
Message 9 of 12
Now I am able to run the code successfully.
I am able to see inspection dimensions in tabular column.
I would like to tabulate dimensions other than inspection dimensions.
Is it possible, please let me know.
Message 10 of 12
Hi guys,
tried it but all the columns are empty.
it's not showing the dimensions.
please help
Message 11 of 12
ThomasCassan
Hello guys
i have a special update wish to this theme
Automatically create check size table from existing part dimensioning.
Create a table that automatically retrieves and lists all inspection dimensions from the respective model file (.ipt and .iam).
Suggestion for possible columns:
Designation, dimension with tolerance, nominal dimension, tolerance, maximum dimension, minimum dimension, tolerance field, inspection rate in %.
I appreciate a lot your work!!!!
thx in advance
Tom
Message 12 of 12
TecnicoPanni
Hello, maybe you all can help me (i'm not so practice of ilogic).
I'd like to modify this Ilogic code in a way to obtain the following fields in the table.
-Columm1: the Label of the inspection dimension
-Columm2: the Value of the inspection dimension (as it already is)
-Columm3: the upper tolerance of the inspection dimension
-Columm4: the lower tolerance of the inspection dimension
-Columm5: the inspection rate of the inspection dimension
The result should be as in the followig sample.
An additional request: is there any way to make this table automatically updated each time I will insert a new or delete an inspection dimension?
Thank you so much, everybody
