Saving drawing title block templates
Hello!
I've had a little problem saving title block templates. After I save new template, it should appear under Drawing resources -> Title Blocks, but in my case - it doesn't.
Here is how I create a slightly modified title block, maybe I am missing a step or something:
1) Finish sketch -> save as -> name it ''ANSI example''
Now it appears in the Title Blocks
But when a new drawing is created, it doesn't appear in the Drawing Resources:
GosponZ
Where did you save template? Is it path in Aplication option same path to your template?
rjay75
In addition to checking that you're modifying the drawing in your templates path also if you have a project configured check that the template is saved in its template path as well.
Windows search doesn't find any files named ''ANSI example'', so I think it isn't even meant to be a global template, but a part of that particular drawing.
So now I just saved the whole empty drawing as a template and it appears in the ''create new file'' menu.
GosponZ
Try to read post above and make screen shot of aplication option on file tab
rjay75
Lauris, it is correct you wouldn't find the seperate files of the title blocks. All the items in the Drawing Resources are not saved to external files. They are stored within the document they are created in. So they must be added to whatever template you're going to use.
