Count all parts with specific iProperties in main assembly and subasemblies
ILU
ILU
hi There,
I am trying to figure out a easy way of counting all visible parts with certain iProperties. Until now I made the bellow code which is working OK but it is counting only parts that are in main assembly, I can't figure it out how to access the parts from mine subassemblies.
Tanks in advance for your help
'Assembly object as ComponentDefinition
Dim oAsmComp As AssemblyDocument = ThisDoc.Document
oAsmCompDef = oAsmComp.ComponentDefinition
Dim iQtyTotlal As Integer = 0
Dim iQty18MB As Integer = 0
Dim iQtyMDF As Integer = 0
Dim iQty38SP As Integer = 0
Dim iQty10MB As Integer = 0
For Each oOccurrence In oAsmCompDef.Occurrences
	Dim oName As String
	oName = oOccurrence.Name
	'18 MB
	Dim MB18 As String = iProperties.Value(oName, "Project", "Description")
	If MB18.Contains("18 MB") Then
		If Component.Visible(oName) = True Then
			iQty18MB += 1
			iQtyTotlal+=1
	Dim MB10 As String = iProperties.Value(oName, "Project", "Description")
	If MB18.Contains("10 MB") Then
			iQty10MB += 1
			iQtyTotlal+=1
	If iProperties.Value(oName, "Project", "Description") = "38 SP" Then
			iQty38SP += 1
			iQtyTotlal+=1
	If iProperties.Value(oName, "Project", "Description") = "18 MDF" Then
			iQtyMDF += 1
			iQtyTotlal+=1
	'	End if
Next
MsgBox("Into this assembly are: " & vbCrLf & vbCrLf & vbCrLf _
& iQty38SP & " - Visible 38mm Block-Panels." & vbCrLf & vbCrLf _
& iQty18MB & " - Visible 18mm Panels." & vbCrLf & vbCrLf _
& iQty10MB & " - Visible 10mm Panels." & vbCrLf & vbCrLf _
& iQtyMDF & " - Visible MDF's." & vbCrLf & vbCrLf & vbCrLf _
& iQtyTotlal & " - In Total." _
, vbOKOnly, "QTY of visible panels into this assemly")
A.Acheson
Here is the recursive sub routines you are needing to traverse through the sub assemblies. Working with assemblies here is a good article. You will notice a function for working with the property sets. They give you more access to modify and to check iProperties and are a little more robust when working with multiple documents like drawings etc.  Here is a good article about working with API property sets and a there is a sub routine shown below  to  list all  of Property sets and Properties.
Sub Main
	Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
	Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oAsmDoc, "Search for visible components") 'Make this a single transaction
	TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences)
	oTransaction.End 'End the transaction
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    Dim oOccDoc As Document
	For Each oOcc As ComponentOccurrence In Occurrences
		If oOcc.DefinitionDocumentType = kPartDocumentObject Then
			oOccDoc = oOcc.Definition.Document
			'Get iproperty using API Property Sets
			Dim sDescription As String = ReadProperty(oOccDoc, "Design Tracking Properties", "Description")
			'Get iproperty using ilogic
			'Dim sDescription As String = iProperties.Value(oOcc.Name, "Project", "Description")
			    If oOcc.Visible = True AndAlso sDescription.Contains("18 MB") Then
					iQty18MB += 1
					iQtyTotlal+=1
				ElseIf oOcc.Visible = True AndAlso sDescription.Contains("10 MB")Then
					iQty10MB += 1
					iQtyTotlal += 1
				ElseIf oOcc.Visible = True AndAlso sDescription.Contains("38 SP")Then
			 		iQty38SP += 1
					iQtyTotlal += 1
				ElseIf oOcc.Visible = True AndAlso sDescription.Contains("18 MDF")Then
					iQtyMDF += 1
					iQtyTotlal+=1
		' Check to see if this occurrence represents a subassembly
		'And recursively Call this Function To traverse through it.
        ElseIf oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
			TraverseAssembly(oOcc.SubOccurrences)
    Next
End Sub
Public Function ReadProperty(doc As Document, setName As String,name As String) As String
    Dim propSet = doc.PropertySets.Item(setName)
    Dim prop = propSet.Item(name)
    Return prop.Value
End Function
Sub ListallPropertysets
  Dim doc As Document
 doc = ThisApplication.ActiveDocument
  Dim ps As PropertySet
  For Each ps In doc.PropertySets
   Logger.Info( ps.Name + " / " + ps.InternalName)
    Dim p As [Property]
    For Each p In ps
      Logger.Info( "  " + p.Name + " /" + Str(p.PropId))
    Next
  Next
End Sub
Regards
Alan
ILU
Thanks @A.Acheson it work like charm.
I do not really get what is with " function for the property sets " or how can it help me in mine future projects, but I am going to have a look over your links and try to understand as much as possible.
Thanks once again
