Can't move Centermark Extension Points
abdullah_elq
abdullah_elq
I am trying to pull the top of a Centermark line to the top of a drawing view. My code neither works nor crashes. Does anyone have any suggestions?
Dim oCM As Centermark = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCentermarkFilter, "Pick Centermark")
Dim oDV As DrawingView = oCM.Parent.DrawingViews(1)
Dim Coords(1) As Double
Coords(0) = oCM.Position.X
Coords(1) = oDV.Top
'Doesn't do anything or throw an error
oCM.ExtensionPointTwo.PutPointData(Coords)
dalton98
I'm not sure why that doesn't work. A suggestion would be to just change the geometry of the extension point directly. It also doesn't seem to mind if you dont give the point an x cordinate.
Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0, oDV.Top)
oCM.ExtensionPointTwo = oPoint
abdullah_elq
Thank you very much. That worked!
