Hello, I am having trouble with component.replace not being able to find a part. I have no clue whats going on with this one, any help would be appreciated. I am running a rule that replaces components and it refuses to work for some of these parts. I copy and paste the the exact file name, i have 4 other sub mains doing similar component replace functions and they work, just not this one. All of the parts its trying to find all live in our purchased parts drive so i dont know why one would work and not the other. Ive been using this technique for a while and this is the first one to fail. LugValve is failing here.
Sub main Flange Elbow Gasket LugValve CLAValve Parameters End Sub Sub Flange Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisDoc.Document.ComponentDefinition Dim oOccurrence As ComponentOccurrence Dim oDesc As String For Each oOccurrence In oAsmCompDef.Occurrences oDesc = oOccurrence.Name oDesc2 = Left(oDesc, 4) If oDesc2 = "5063" Then Select Case DSR Case = "2.0 in" Component.Replace(oDesc, "50633.ipt", True) Case = "3.0 in" Component.Replace(oDesc, "50635.ipt", True) Case = "4.0 in" Component.Replace(oDesc, "50637.ipt", True) Case = "5.0 in" Component.Replace(oDesc, "50638.ipt", True) Case = "6.0 in" Component.Replace(oDesc, "50639.ipt", True) End Select End If Next End Sub Sub Elbow Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisDoc.Document.ComponentDefinition Dim oOccurrence As ComponentOccurrence Dim oDesc As String For Each oOccurrence In oAsmCompDef.Occurrences oDesc = oOccurrence.Name oDesc2 = Left(oDesc, 4) If oDesc2 = "5006" Then Select Case DSR Case = "2.0 in" Component.Replace(oDesc, "50063.ipt", True) Case = "3.0 in" Component.Replace(oDesc, "50065.ipt", True) Case = "4.0 in" Component.Replace(oDesc, "50067.ipt", True) Case = "5.0 in" Component.Replace(oDesc, "50068.ipt", True) Case = "6.0 in" Component.Replace(oDesc, "50069.ipt", True) End Select End If Next End Sub Sub Gasket Select Case DSR Case = "2.0 in" Component.IsActive("2.00 X 0.125 CL150:1") = True Component.IsActive("3.00 X 0.125 CL150:1") = False Component.IsActive("4.00 X 0.125 CL150:1") = False Component.IsActive("5.00 X 0.125 CL150:1") = False Component.IsActive("6.00 X 0.125 CL150:1") = False Case = "3.0 in" Component.IsActive("2.00 X 0.125 CL150:1") = False Component.IsActive("3.00 X 0.125 CL150:1") = True Component.IsActive("4.00 X 0.125 CL150:1") = False Component.IsActive("5.00 X 0.125 CL150:1") = False Component.IsActive("6.00 X 0.125 CL150:1") = False Case = "4.0 in" Component.IsActive("2.00 X 0.125 CL150:1") = False Component.IsActive("3.00 X 0.125 CL150:1") = False Component.IsActive("4.00 X 0.125 CL150:1") = True Component.IsActive("5.00 X 0.125 CL150:1") = False Component.IsActive("6.00 X 0.125 CL150:1") = False Case = "5.0 in" Component.IsActive("2.00 X 0.125 CL150:1") = False Component.IsActive("3.00 X 0.125 CL150:1") = False Component.IsActive("4.00 X 0.125 CL150:1") = False Component.IsActive("5.00 X 0.125 CL150:1") = True Component.IsActive("6.00 X 0.125 CL150:1") = False Case = "6.0 in" Component.IsActive("2.00 X 0.125 CL150:1") = False Component.IsActive("3.00 X 0.125 CL150:1") = False Component.IsActive("4.00 X 0.125 CL150:1") = False Component.IsActive("5.00 X 0.125 CL150:1") = False Component.IsActive("6.00 X 0.125 CL150:1") = True End Select End Sub Sub LugValve Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisDoc.Document.ComponentDefinition Dim oOccurrence As ComponentOccurrence Dim oDesc As String For Each oOccurrence In oAsmCompDef.Occurrences oDesc = oOccurrence.Name oDesc2 = Left(oDesc, 3) If oDesc2 = "310" Then Select Case DSR Case = "2.0 in" Component.Replace(oDesc, "310200-BFA12375.ipt", True) Case = "3.0 in" Component.Replace(oDesc, "310300-BFA12375.ipt", True) Case = "4.0 in" Component.Replace(oDesc, "310400-BFA12375.ipt", True) Case = "5.0 in" Component.Replace(oDesc, "310500-BFA12375.ipt", True) Case = "6.0 in" Component.Replace(oDesc, "310600-BFA12375.ipt", True) End Select End If Next End Sub
