Component.Replace, file not found??
Preston_Reed
Preston_Reed
Hello, I am having trouble with component.replace not being able to find a part.  I have no clue whats going on with this one, any help would be appreciated.  I am running a rule that replaces components and it refuses to work for some of these parts.  I copy and paste the the exact file name, i have 4 other sub mains doing similar component replace functions and they work, just not this one.  All of the parts its trying to find all live in our purchased parts drive so i dont know why one would work and not the other.  Ive been using this technique for a while and this is the first one to fail.  LugValve is failing here.
Sub main
	Flange
	Elbow
	Gasket
	LugValve
	CLAValve
	Parameters
End Sub
Sub Flange
	Dim oAsmCompDef As AssemblyComponentDefinition
	oAsmCompDef = ThisDoc.Document.ComponentDefinition
	Dim oOccurrence As ComponentOccurrence
	Dim oDesc As String
	For Each oOccurrence In oAsmCompDef.Occurrences
		oDesc = oOccurrence.Name
		oDesc2 = Left(oDesc, 4)
		If oDesc2 = "5063" Then
			Select Case DSR
				Case = "2.0 in"
					Component.Replace(oDesc, "50633.ipt", True)
				Case = "3.0 in"
					Component.Replace(oDesc, "50635.ipt", True)
				Case = "4.0 in"
					Component.Replace(oDesc, "50637.ipt", True)
				Case = "5.0 in"
					Component.Replace(oDesc, "50638.ipt", True)
				Case = "6.0 in"
					Component.Replace(oDesc, "50639.ipt", True)
			End Select
		End If
	Next
End Sub
Sub Elbow
	Dim oDesc As String
		If oDesc2 = "5006" Then
			Select Case DSR
				Case = "2.0 in"
					Component.Replace(oDesc, "50063.ipt", True)
				Case = "3.0 in"
					Component.Replace(oDesc, "50065.ipt", True)
				Case = "4.0 in"
					Component.Replace(oDesc, "50067.ipt", True)
				Case = "5.0 in"
					Component.Replace(oDesc, "50068.ipt", True)
				Case = "6.0 in"
					Component.Replace(oDesc, "50069.ipt", True)
			End Select
		End If
	Next
End Sub
Sub Gasket
	Select Case DSR
		Case = "2.0 in"
			Component.IsActive("2.00 X 0.125 CL150:1") = True
			Component.IsActive("3.00 X 0.125 CL150:1") = False
			Component.IsActive("4.00 X 0.125 CL150:1") = False
			Component.IsActive("5.00 X 0.125 CL150:1") = False
			Component.IsActive("6.00 X 0.125 CL150:1") = False
		Case = "3.0 in"
			Component.IsActive("2.00 X 0.125 CL150:1") = False
			Component.IsActive("3.00 X 0.125 CL150:1") = True
		Case = "4.0 in"
			Component.IsActive("4.00 X 0.125 CL150:1") = True
		Case = "5.0 in"
			Component.IsActive("5.00 X 0.125 CL150:1") = True
		Case = "6.0 in"
			Component.IsActive("6.00 X 0.125 CL150:1") = True
	End Select
End Sub
Sub LugValve
	Dim oDesc As String
		oDesc2 = Left(oDesc, 3)
		If oDesc2 = "310" Then
			Select Case DSR
				Case = "2.0 in"
					Component.Replace(oDesc, "310200-BFA12375.ipt", True)
				Case = "3.0 in"
					Component.Replace(oDesc, "310300-BFA12375.ipt", True)
				Case = "4.0 in"
					Component.Replace(oDesc, "310400-BFA12375.ipt", True)
				Case = "5.0 in"
					Component.Replace(oDesc, "310500-BFA12375.ipt", True)
				Case = "6.0 in"
					Component.Replace(oDesc, "310600-BFA12375.ipt", True)
			End Select
		End If
	Next
End Sub
dalton98
Only thing I can think is changing the 'Replace all' to false, since you go through every component anyways. Also maybe try adding the full file name for those parts since they are not in the project folder.
Preston_Reed
Ok so i ended up finding out that for some reason this part is saved in multiple locations in our purchased drive.  Thats what was causing the issue.
