Could not Promote Wires in c sharp
Message 1 of 1
I am trying to promote wires from the construction geometry to the sketch.
It works very well in VBA macro.
somehow it fails when it comes to c sharp.
I have attached the a part document containing wires and below c sharp code is used to promote wires.
The function PromoteWires() is written to promote the wires.
In this function, a part document is made as active document.
Required node(construction geometry) which contains wires is selected.
and promote wire command is fired using command manager.
Result is, it simply adds a sketch but the sketch doesn't contain required sketch entities.
Please Suggest if i am missing anything in doing it.
Looking forward for your reply.
Thank you.
C Sharp Snippet:
private void PromoteWires()
PartDocument oPartSATDoc = (Inventor.PartDocument)m_inventorApp.ActiveDocument;
BrowserNode oTopBrowserNode;
oTopBrowserNode = oPartSATDoc.BrowserPanes.ActivePane.TopNode;
BrowserNode oRequiredNode;
oRequiredNode = recurseNodes(oTopBrowserNode, "Wires");
oRequiredNode.DoSelect();
CommandManager oCommandMgr;
oCommandMgr = m_inventorApp.CommandManager;
ControlDefinition oControlDef;
oControlDef = oCommandMgr.ControlDefinitions["PartConstructionPromoteWireCtxCmd"];
oControlDef.Execute();
private Inventor.BrowserNode recurseNodes(Inventor.BrowserNode oTopNode, String strWantedNode)
BrowserNode tempnode = null;
if (oTopNode.FullPath.Contains(strWantedNode))
tempnode = oTopNode;
else
BrowserNode oBN = null;
if (oTopNode.BrowserNodes.Count != 0)
foreach (BrowserNode oBN1 in oTopNode.BrowserNodes)
oBN = oBN1;
tempnode = recurseNodes(oBN, strWantedNode);
if (!(tempnode == null))
break;
else
tempnode = null;
return tempnode;
Replies (0)
