Creating custom iProperties
We have created new drawing templates where the titleblock refers to custom iProperties for the values. When we go into old drawings, we can copy/poste the titleblock in but we need to create the custom iProperties every time and this gets tedious. I need a simple macro to create custom fields for "Dwg Line 1", "Dwg Line 2", "EN#" etc. The values can be empty. Just creating the property will be a big help.
Since I can't record a macro and then clean it up, I am kind of lost...
See if this helps
Public Sub CustomProps()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oPropSets As PropertySets
Set oPropSets = oDoc.PropertySets
Dim oPropSet As PropertySet
Set oPropSet = oPropSets.item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Dim oProp As Property
Dim iPropID As Variant
vPropID = 2
On Error Resume Next
Call oPropSet.Add("", "Dwg Line 1")
Call oPropSet.Add("", "Dwg Line 2")
End Sub
KWiKMcad
Kent Keller
"dmikul" wrote in message news:6325948@discussion.autodesk.com...
Kent - THANKS! That worked beautifully. I really appreciate the help. Dave
