copying paramater in .idw?
sreed
sreed
I have a user parameter called "ModelDesignState" that is multi-value.  I have this in my .idw because it is tied to a rule that reaches out to the model.  I am wondering if there is a way to copy this parameter out of my .idw and paste it into another .idw?  Is there a way to make it a global parameter or something like that?
kelly.young has embedded your image for clarity.
Curtis_Waguespack
Hi @sreed,
You can just add this to the top of the iLogic rule that is referencing the parameter. This will check for the parameter first, and then create it if not found.
Note that as written it also sets / resets the list regardless of whether the parameter exists or is created new, which is likely what you want, but maybe not.
I hope this helps.
Curtis
Try
    'check for parameter
    oTest = Parameter("ModelDesignState")
Catch
    'create multi-value text parameter
    ThisDoc.Document.Parameters.UserParameters.AddByValue _
    ("ModelDesignState", "WorkInProgress", UnitsTypeEnum.kTextUnits)
End Try
'set list
MultiValue.SetList("ModelDesignState", "WorkInProgress", "Pending", "Released")
marcin_otręba
You can add it to your template.
For old ones you can run rule and write them to each, you can use template file and read parameter from it and place it to old ones...
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
sreed
Thanks for the help and sorry about making duplicate posts.  I have put your solution into my rule, but now I am getting an error with a different rule.  I will attach a drawing and some rules so you can see what i'm talking about.
As you can tell I don't know much about rules.
Also when we change the parameter in the form it automatically goes back to "work in progress"
Curtis_Waguespack
Hi @sreed
I just saw your last post concerning the errors. Did you get this sorted out?
I ran the rules in a test drawing file, and all worked well, I did not see the parameter switch back in the form either.
What version of Inventor are you using? I might be able to provide a simple example file set for you to look at.
I hope this helps.
Curtis
sreed
Yes I got it figured out,  there was an error that I did not notice before.
Thank you for your help
