Copy select iProperties from file to file
kfc10
kfc10
Hello, can anyone help?
This code copies all iProperties. I only need to copy some iProperties, not all iProperties.
I only need to copy iProperties named and Value. "test1" and "test2"
Sub Main()
Dim oFileName As String = "C:\iLogic_Main\a.ipt"
Dim mojecesta As String = "C:\iLogic_Main\b.iam"
'			mojecesta = ThisDoc.PathAndFileName(True)
Dim copyFrom As Document = ThisApplication.Documents.Open(oFileName, False) 'Document to copy from
Dim copyTo As Document = ThisApplication.Documents.Open(mojecesta, False) 'Document to copy to
CopyEventsPropSet(copyFrom, copyTo)
End Sub
Sub CopyEventsPropSet(CopyFrom As Document, CopyTo As Document)
	Dim refiProps As PropertySet = CopyFrom.PropertySets.Item("Inventor User Defined Properties")
	Dim deriPorps As PropertySet = CopyTo.PropertySets.Item("Inventor User Defined Properties")
		Dim oProp As Inventor.Property
		For Each oProp In refiProps
	Dim oProp1 As Inventor.Property
	Dim oProp2 As Inventor.Property
	Try
				deriPorps.Add(oProp.Value, oProp.Name)
	Catch ex As Exception
	End Try
		Next
	CopyFrom.Close(True)
End Sub
I tried it and I don't get it at all.
The attachment is in version 2022
JelteDeJong
this is untested code but I think it will do what you want.
Public Sub Main()
    CopyProperty(copyFrom, copyTo, "test1")
    CopyProperty(copyFrom, copyTo, "test2")
    copyFrom.Close(True)
End Sub
Sub CopyProperty(CopyFrom As Document, CopyTo As Document, propertyName As String)
    Dim fromProps As PropertySet = CopyFrom.PropertySets.Item("Inventor User Defined Properties")
    Dim toPorps As PropertySet = CopyTo.PropertySets.Item("Inventor User Defined Properties")
    Dim fromProp As [Property] = fromProps.Item(propertyName)
    Try
        Dim toProp As [Property] = toPorps.Item(propertyName)
        toProp.Value = fromProp.Value
        toPorps.Add(fromProp.Value, fromProp.Name)
    End Try
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
kfc10
Yes, everything works. That's great. Thank you very much for your help.
