Edit dimension of a part within an assembly with API
fpusch
Message 1 of 9
fpusch
I built an assembly with self made parts in it in Inventor. Now I want to create a code with API in the assembly which changes the dimensions of the parts depending on the input of the API interface. How do I write a Code for that? I only know how to use API in parts.
Thank you!
Replies (8)
Message 2 of 9
JelteDeJong
I'm missing a lot of details needed to help you. But in general, it works like this. You loop over all referenced documents by the assembly. Find the part you need. Use the part API on the part document. that would look something like this.
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
For Each refDoc As Document In doc.AllReferencedDocuments
    ' find the document we need
    If (refDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then Continue For
    If (refDoc.FullFileName.Contains("") = False) Then Continue For
    ' If the code came here the refDoc is the document we need
    Dim partDoc As PartDocument = refDoc
    ' use the partDoc with the api that you already know
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 9
robertast
@fpusch  Can you post the file and tell more exactly what you want to get? If you only manage parts depending on the size of the product, then this can be done easier and without API
Message 4 of 9
fpusch
@robertrast I have to create a computer mouse for a class and the user should be able to use the interface which you can create with the API user forms.
So I'm doing a list with some names as an example:
- assembly-name: computer mouse
- name of a part which needs to have changeable dimensions: mouse body
- parameter which needs to be changed within "mouse body": P:01
- name of an input box from the userform for P:01: hand width
And I have to do this with a few parameters in a few parts in the same assembly
Message 5 of 9
fpusch
@JelteDeJong first of all: thank you. Further below in this question I made a reply in which you can see a bit more details about what i need to do.
I have a few questions to your code: the API editor doesnt let me use a few things in the way you postedd it. For example it doesnt let me put the "For" at the end of the lines which begin with "If".
What are things I need to change put my assembly, part or variable names in?
Thank You!
Message 6 of 9
robertast
@fpusch
Here is one way to solve your problem
Message 7 of 9
robertast
This is the second time when no API is required at all, and management is done from another part file that is not involved in the assembly.
Message 8 of 9
fpusch
@robertastThank you for your input, unfortunately I need to solve the problem with the VBA / API editor
Message 9 of 9
robertast
It's all just just using video_A  non-iLogic but VBA. Also assign parameters
