Learning ilogic
Learning ilogic
simonmunyua6
Message 1 of 8
Learning ilogic
simonmunyua6
Am interested in learning ilogic programming and i don't know where to start. Please help me with any link where i can get more information.
Accepted solutions (3)
Replies (7)
Message 2 of 8
vpeuvion
Hi, You can find all the information here, then the forums very useful to learn.
Hope this can help you.
Vincent.
Message 3 of 8
JMGunnar
Start width AU
https://www.autodesk.com/autodesk-university/au-online
search for ilogic
Johan
Message 4 of 8
A.Acheson
To tie into the API help suggestion, here is a must read website. Alot of the concepts will be hard to digest and some will be for the advanced user such as add in and using visual studio for code writing but I would suggest start here and digest what you can.
https://modthemachine.typepad.com/my_weblog/2013/02/inventor-api-training-lesson-1.html
Be aware that ilogic is a short version of coding using VB.NET language  so has it's limitations and differences than coding directly with VB.Net and the API. The API help samples is mostly written in VBA. You will see there is some slight differences but 80% of the code is the same.
Regards
Alan
Message 5 of 8
fidel.makatiaD5W7V
Hi @simonmunyua6 , you can also use the link below to access inventor 2022 official documentation. you will be able to learn ilogic, VBA and inventor APIs to use with your inventor application during your learning process.
Inventor 2022 Help | Get Started Tutorials | Autodesk
Let me know if this is useful
Fidel Makatia
Developer Advocate
href=https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-0BD48573-7193-4285-87B7-6727555D053E rel= "noopener noreferrer">Inventor 2022 Documentation |
Message 6 of 8
ravikmb5
best way is to learn basics like creating parameters, sketches, features like extrude revolve etc
if u want i will send u some practise codes for creating simple models
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Message 7 of 8
dusan.naus.trz
Message 8 of 8
simonmunyua6
This one was a great video for a start and i have really learned a lot on ilogic. At least I know where to start and what to start with. Thanks!
