copy paste to an excel sheet with Ilogic
Darkforce_the_ilogic_guy
Advisor Advisor
what I want is simple
I can do this simple and very fast by add it to copy  and then open the excel
select cell A2 and then ctrl + V and done
but I add the same infomation to cell A2 i all goes in A2 .. and don´t see the tabs and Enter i the code
I do not write it directly to Excel as this is super slow
I want it fast and easy also for other then my
bradeneuropeArthur
I don't understand what you would like to do!
Could you explain it step by step?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
the main reason I would to this is speed.  it about 100 times fastere then write to Excel API
I do not really care how the data get to the excel sheet.  but write it to excel line by line .. is too slow
I need to send it in one go
and I need the data in excel to better analyse it and give the user the info they need faste and in an format that easyly can use to fix any problem.
for now it is see if any drawing is missing or out of date.... and see it the user have added weight data  correctly
later jeg planing to tell the users if the assambly they have copy
1.use some material that we are not ably to get any more
2. or if there is an likely cheaper alternative
3. maybe if all electrick componemt metting the country standard
