Copy&Replace Adaptive Component
c_hoppen
c_hoppen
I would like to replace components in an assembly that contain adaptive elements. Replacing the components themselves is straightforward, but I can't find a way to replace the references to the adaptive elements. The Copy function in the assembly environment can do this (see lower left screenshot).
I have not found any information about this in the API documentation or in this forum.
Is there a trick to it? Unfortunately, I'm afraid this is not possible via the API, as the context menu of adaptive elements does not offer any options either.
Christoph
C_Haines_ENG
To clarify, the Assembly "Component -> Copy" function does what you want?
c_hoppen
Yes. The lower left screenshot shows the result after "Copy Components":
Apparently, the function uses an internal mechanism that is not available via the API.
C_Haines_ENG
You could actually copy the file, and then rename it, and add it back into the assembly.
I believe it would retain its references, just not its constraints. You can use System.IO to copy files.
System.IO.File.Copy("FilePathToCopy","FilePathOfCopied")
