Derived parameter table
vishnuteja_srikanti
vishnuteja_srikanti
i have derived parameters of part occurance in assembly fx parameters as shown below
now i want to add derive few more parameters from same derived parameter table using vb.net code
any idea how can i execute this?
i used below code to add parameter table in assembly doc
ptable = pAsmDoc.ComponentDefinition.Parameters.DerivedParameterTables.Add2(comp_flnmae, pretricol)
now i want to derive few more parameters from same parameter table .
WCrihfield
Hi @vishnuteja_srikanti.  When using that DerivedParameterTables.Add2 method, it gives you the DerivedParameterTable object that it created.  But if coming back later, you would just have to find that same DerivedParameterTable that you created again, so that you can use its DerivedParameterTable.LinkedParameters property.  That is a Read/Write property, with an ObjectCollection type value.  So, first collect all the parameters from that source document that you want to Link to this one into an ObjectCollection, then set that as the value of this property.  By the way, if you have multiple DerivedParameterTables, and need to know which one is for which source document, I believe you can use the DerivedParameterTable.ReferencedDocumentDescriptor property, then its DocumentDescriptor.FullDocumentName property, or its DocumentDescriptor.ReferencedDocument property.  If attempting to go the DerivedParameterTable.ReferenceComponent route, that is not talking about a regular assembly component (ComponentOccurrence ), but something (ReferenceComponent type object) that was 'derived into' the current document, resulting in these parameters getting included.
Wesley Crihfield
(Not an Autodesk Employee)
C_Haines_ENG
Conveniently, I JUST wrote a method to do this. You can select a dimension in a sub component of an assembly and it will link it to the assembly you are in.
Sub Main
	Dim oDoc As Document = ThisDoc.Document
	Dim oLinkDim As DimensionConstraint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchDimConstraintFilter, "Select Dimension")
	Dim oLinkPath As String = oLinkDim.Parameter.Parent.FullFileName
	Dim oDocParams As Parameters = oDoc.ComponentDefinition.Parameters
	Dim oLinkedTable As DerivedParameterTable = CheckIfLinked(oDocParams, oLinkPath)
	Call LinkParameter(oLinkDim.Parameter, oLinkedTable)
End Sub
Function CheckIfLinked(oDocParams As Parameters, oLinkPath As String)
	For Each oDerivedTable As DerivedParameterTable In oDocParams.DerivedParameterTables
		If oDerivedTable.ReferencedDocumentDescriptor.FullDocumentName = oLinkPath Then Return oDerivedTable
	Next
	Return oDocParams.DerivedParameterTables.Add(oLinkPath)
End Function
Sub LinkParameter(oNewParam As Parameter, oLinkedTable As DerivedParameterTable)
	Dim oCollect As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oLinkedParam As DerivedParameter In oLinkedTable.LinkedParameters
		oCollect.Add(oLinkedParam.ReferencedEntity)
	Next
	oCollect.Add(oNewParam)
	oLinkedTable.LinkedParameters = oCollect
End Sub
vishnuteja_srikanti
hello haines
i actually tried this method for first time when you are adding params in derived table it is working fine later once you complete the process and for next time it is showing unspecified error
in below code i have created 2 object collections plink params is which dumps parameters into derived parameter table and also collect already listed parameters in derived parameters table and pretricol is collection of new parameters which i want to add with linked parameters in same table so this how i wrote is anything i am missing
actually the same worked fine until i complete process for first time after when i close form and again run the same code for other component operation i am having this error
C_Haines_ENG
Change:
plinkparam.add(pParma)
to
plinkparam.add(pParma.ReferencedEntity)
when getting parameters from a derivedparameter table, they are derived parameters and Inventor wont accept adding them back in like that as you would be adding a link to a link. Get the ReferencedEntity to get the actual Parameter to add it back in.
