Copy all iProperties from Mirrored Part
donaldleigh
donaldleigh
Hi all
I have found this rule in the forum here and I would like not only copy the custom iProperties but all the iProperties.
Is anyone able to help me out.
Cheers
Donald (Inventor 2014)
When you create a symmetric part in assembly, it automatically
The property is copied ...
Why?
Sergio.D.Suárez
Hi, here you have an ilogic code, I think it could work.
I try to simplify it a bit by taking the information from your original code.
Dim oDerPro As Inventor.Property
Dim oDerived As Inventor.Document = ThisApplication.ActiveDocument
If oDerived.ReferencedDocuments.Count = 0 Then Exit Sub
Dim oReferenced As Inventor.Document = oDerived.ReferencedDocuments(1)
For Each oRefPro As Inventor.Property In oReferenced.PropertySets.Item("Inventor Summary Information")
	Try
   oDerived.PropertySets.Item("Inventor Summary Information")(oRefPro.Name).Value = oRefPro.Value
   Catch
   End Try
Next
For Each oRefPro As Inventor.Property In oReferenced.PropertySets.Item("Inventor Document Summary Information")
	Try
   oDerived.PropertySets.Item("Inventor Document Summary Information")(oRefPro.Name).Value = oRefPro.Value
   Catch
   End Try
Next
For Each oRefPro As Inventor.Property In oReferenced.PropertySets.Item("Design Tracking Properties")
	Try
   oDerived.PropertySets.Item("Design Tracking Properties")(oRefPro.Name).Value = oRefPro.Value
   Catch
   End Try
Next
If you want this code combined with your previous code, you could try this new code
	Try
   Catch
   End Try
Next
	Try
   Catch
   End Try
Next
	Try
   Catch
   End Try
Next
Dim oDerProps As PropertySet = oDerived.PropertySets.Item("Inventor User Defined Properties")
Dim oProList() As String = {"*", "OTHER_iPRO" }
For Each oRefPro As Inventor.Property In oReferenced.PropertySets.Item("Inventor User Defined Properties")
    'Check for existing, add if not existing
    Dim oSkip As Boolean = True
    For Each ProName As String In oProList
        'Ucase ignores upper/lower case in names
        If UCase(ProName) <> UCase(oRefPro.Name) And ProName <> "*" Then Continue For
        oSkip = False
        Exit For
'Copy from derived properties to current properties
    Next
    If oSkip Then Continue For
    Try
        oDerPro = oDerProps(oRefPro.Name)
    Catch
        oDerPro = oDerProps.Add("", oRefPro.Name)
    End Try
    oDerPro.Value = oRefPro.Value
Next
 I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
bradeneuropeArthur
Hi @donaldleigh
You could vote the following idea for this feature to be implemented!
 Derive I-properties!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
