Coping from Inventor to AutoCADD
Good Morning!
Help Please..
Question: Is it possible to copy my drawing from my Inventor Block Sheet in order to paste into Auto Cadd.   And to be able to make change once pasted into AutoCadd?
I really need to place a few drawings from Inventor to AutoCadd without having to do my original drawing completely over.
Please, any help, directions  or suggestion would greatly be appreciated.
Thank you!
bradeneuropeArthur
open the inventor dwg simply in autocad
The drawing views are available as blocks in autocad.
Insert these blocks into whatever you need, like other dwg file (copy paste).
Or edit with block editor
Or explode the block.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
